problems w/ camber kit plz help
Old May 22, 2003 | 11:42 PM
90civichbsi's Avatar
Default problems w/ camber kit plz help
well i just got done installing tein ss coilovers, complete ES bushing kit, new balljoints, and a full SPC camberkit front and rear. the fronts are adjustable ball joints. this is a 1990 honda civic 3dr
the problem is, in the front when i tried to get it aligned, and adjusted the camber kit out, if we were to put the weight of the tires back down, the adjustable balljoint would hit the inside fenderwell. What can i do?
we had to set it at -1.9 camber to clear the fenderwell
anyone else run into this problem? how can i fix it?
this was the hieght before with sagging sprint springs and blown shocks. I have since raised it about a 1" to 1.25"
Old May 23, 2003 | 08:28 AM
Default Re: problems w/ camber kit plz help (90civichbsi)
cant anyone help me?
Old May 23, 2003 | 08:59 AM
matt j's Avatar
with the adjustable ball joints when you adjust out the camber they will hit the fenderwell, every one that i have seen (except for the rare few) have done that, most people cut a piece of the inside fenderwell (under the hood) so that it wont hit
Old May 23, 2003 | 09:40 AM
Default Re: problems w/ camber kit plz help (mattED6)
do the ancor bolt kits have this problem?
Old May 23, 2003 | 10:14 AM
sitrucjr's Avatar
i have the spc balljoints on my civic too and what i did was bend the fenderwell outward and then it was fine
Old May 23, 2003 | 10:35 AM
REDBARON's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">do the ancor bolt kits have this problem?</TD></TR></TABLE>
Yes they do, but only if you have it lowered to much. I have mine lowered to 1", and they don't hit.
Old May 23, 2003 | 11:58 AM
StlSupra's Avatar
just to jump into this thread. if people had to re-do the camber kits what would they use?
Old May 23, 2003 | 12:02 PM
1_bad_EF's Avatar
Default Re: (StlSupra)
not the achor bolts style. I would use the concentric upper ball joint style. I had the same problem. I cut and pounded the inner fender.
Old May 23, 2003 | 04:24 PM
Default Re: (1_bad_EF)
what did you guys pound it out with? or cut it, just give me a lil tips, i tried hammering, but it didnt want to budge much
Old May 23, 2003 | 06:20 PM
sitrucjr's Avatar
Default Re: (90civichbsi)
i used a regular adjustable wrench to bend it
and i had both camber kits and i like the adjustable balljoints the best
Old May 23, 2003 | 09:56 PM
ThatRicerDaniel's Avatar
Default Re: (sitrucjr)
sprint extreme camber kit !
Old May 24, 2003 | 01:25 AM
crex23's Avatar
Default Re: (NitrousDreamz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitrousDreamz &raquo;</TD></TR><TR><TD CLASS="quote">sprint extreme camber kit ! </TD></TR></TABLE> This is what I have on my CRX. I used a Saws-All to notch out part of the inner fender so the A-arm would clear.
Old May 24, 2003 | 02:34 PM
will banging in/ cutting the inner fenderwell damage the body structure?
Old May 24, 2003 | 02:50 PM
escocrx's Avatar
chop it. or bang it. the area u are bangin isnt a structural (however u spell it) support.
Old May 24, 2003 | 10:45 PM
SiR Kid's Avatar
New User
Default Re: problems w/ camber kit plz help (escocrx)
Hey, if you don't mind me asking, is that the WW kit? Those Skirts looks prety damn good, makes the car look even lower than it is.
I likee!
Old May 24, 2003 | 10:50 PM
brent_G's Avatar
Default Re: problems w/ camber kit plz help (SiR Kid)
I had that problem wiht mine too...I just adjusted it to where it would just barely fit in there. you could actually here it scrapping the inside soemtimes. But after a while it wore iteself and groove and stopped sqeaking. I was mostly concerned for camber wear on my azenis...and that was plently. Was almost too much. But then again im not too much into tuning a suspension for competetion.
But there was nothign else i could figure out to do. I even tried to beat it out some but there is no room to swing a hammer...nor is it weak enough to bend...
I had the ingalls kit.
Old May 25, 2003 | 09:13 AM
ruiner17's Avatar
Default Re: problems w/ camber kit plz help (screamincivik)
Do these camber kits have problems because the upper arm gets push outward more or further up? get what i'm asking?
thanks
Old May 25, 2003 | 01:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">Hey, if you don't mind me asking, is that the WW kit? Those Skirts looks prety damn good, makes the car look even lower than it is.
I likee!</TD></TR></TABLE>
yes and thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruiner17 &raquo;</TD></TR><TR><TD CLASS="quote">Do these camber kits have problems because the upper arm gets push outward more or further up? get what i'm asking?</TD></TR></TABLE>
it actually goes in the place of the stock ball joint, but this one slides back and forth so you can adjust the camber, they have pics on the SPC site, you will understand then http://www.specprod.com
Old May 25, 2003 | 01:23 PM
brent_G's Avatar
Default Re: problems w/ camber kit plz help (ruiner17)
thanks </TD></TR></TABLE>
Get pushed OUT more. so the will catch on an edge up in the wheel well, and cause it to rest on it and not be lowered all the way
Old May 25, 2003 | 02:59 PM
ruiner17's Avatar
awww, thanks guys. so these vision camber kits will probably have the same problems...right?
FLACO EM1
Suspension & Brakes
25
Dec 5, 2008 07:37 AM
FLACO EM1
Nov 27, 2008 01:39 PM
raynaud
Oct 27, 2004 07:52 PM
hndasiguy
Sep 7, 2003 06:06 AM
teg21
Jul 9, 2002 09:46 AM
