alot of questions
Old May 22, 2003 | 11:27 PM
BumpinVTEC's Avatar
Default alot of questions
hi, i just got a first gen b16 in my da and its my daily driver, what i want from this is a good daily driven reliable setup with the most power, i guy at a local shop said i can get itbs, and use a stock ecu with a vtec controller, is this true? i was kind skeptical cause i just have a mild setup, bolt ons/ cams, etc. and a stock block, can i do this setup? i recently found this on ebay, check it out
http://cgi.ebay.com/ebaymotors...64666
also whats the best tire for just all around driving, its summer so what are good tires for dry traction, like sutocrossing?
i also scored these rims for 70 bucks but one is crack do you think its fixable, heres the link
http://cgi.ebay.com/ebaymotors...:US:6
Old May 23, 2003 | 05:26 AM
dfoxengr's Avatar
Default Re: alot of questions (jrscLSman)
u shouldnt use itbs unless your motor is crucially built up. bad idea. swap out internals instead.
use falken azenis for autox and daily. theyre the best for autox
chavnutsmcchav
Suspension & Brakes
Mar 8, 2016 12:28 PM
JDM*Fiend
Jan 13, 2007 12:58 PM
H22CRX
Apr 9, 2003 10:09 PM
