Does calipers from any other honda/acura fit the my ITR brakes.
i need a hub and 2 calipers to complete a partial rear swap i found. Because all i need is the rear brakes to complete my 5 lug swap (and a complete set of wheels i only have 2 wheels). but is there any other model that came with the same rear calipers or will only ITR calipers and hubs work? I hope someone answers this. im pulling my hair out trying to locate just the rear setup. TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat »</TD></TR><TR><TD CLASS="quote">I've *heard* Accord wagon and maybe some Preludes will work, but I cannot confirm that.</TD></TR></TABLE>
Cool i hope someone can verify this and let me know what years. Is there any way to use my stock suspension and other OE parts to make it just the 5 lug pattern?
Prelude/CRV/Accord wagon bakes are more or less identical. I bought a pair of Prelude calipers for my R and the backing plate was a slightly different size. I needed to either shave off some material from the backing plate or add some washers or something. I don't remember exactly which way it was off because I just sent out my stockers to get rebuilt instead. However...
He's talking about the rear calipers. I believe the calipers themselves are the same as a GSR, but the backing plate is completely different. I don't know if you're able to buy the backing plate separately, because that might make it worth sourcing the plate from the dealer and the caliper from somewhere else. Maybe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond »</TD></TR><TR><TD CLASS="quote">97+ preludes have the exact same brakes I believe.
so i can use prelude rotors,calipers and hubs. but i need type r lower control arm and link? or will all of prelude stuff fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5 »</TD></TR><TR><TD CLASS="quote">Prelude/CRV/Accord wagon bakes are more or less identical. I bought a pair of Prelude calipers for my R and the backing plate was a slightly different size. I needed to either shave off some material from the backing plate or add some washers or something. I don't remember exactly which way it was off because I just sent out my stockers to get rebuilt instead. However...
He's talking about the rear calipers. I believe the calipers themselves are the same as a GSR, but the backing plate is completely different. I don't know if you're able to buy the backing plate separately, because that might make it worth sourcing the plate from the dealer and the caliper from somewhere else. Maybe.</TD></TR></TABLE>
GSR rear calipers look smaller than ITR rear calipers to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia »</TD></TR><TR><TD CLASS="quote">
GSR rear calipers look smaller than ITR rear calipers to me.</TD></TR></TABLE>
i thought GSR was to small as well. Ok i bought the lower control arms the links backing plates and one hub for $250.00 all i need now is one hub and 2 calipers and rotors. I see that the 97-01 prelude has the same rotor. just going by ebay listings. But since im a trial user i only get 5 posts a day (what a pain in the *** especially when you have a post going! oh well someone heres has to know which calipers will work or someone might even have a set of stock calipers for sale! TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT »</TD></TR><TR><TD CLASS="quote">only itr calipers will work properly on the rear. prelude calipers are different.
gsr calipers are smaller.</TD></TR></TABLE>
dammit something better fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benbuilt4u »</TD></TR><TR><TD CLASS="quote">
dammit something better fit.</TD></TR></TABLE>
Why do you want different calipers? There's nothing wrong with the stock ITR brake system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R Driven15 »</TD></TR><TR><TD CLASS="quote">Yes legends will fit on it.</TD></TR></TABLE>
The rears??? We are talking about the rear here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
Why do you want different calipers? There's nothing wrong with the stock ITR brake system.</TD></TR></TABLE>
if you read my original post it says i have the fronts from my JDM swap but im missing the rears.
Are ITR calipers that hard to find? Surely autozone should carry a reman unit...
Edit: http://www.partsamerica.com/Se...liper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">Are ITR calipers that hard to find? Surely autozone should carry a reman unit...
Edit: http://www.partsamerica.com/Se...liper</TD></TR></TABLE>
not a bad idea? but what would i give back for a core my stock civic ones?
They wont know the difference
</TD></TR></TABLE>They wont know the difference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondatec38 »</TD></TR><TR><TD CLASS="quote">I put a set of used NSX calipers on a 95 prelude for fun. They work great.</TD></TR></TABLE>
which ones front or back or both and they dont fit an itr?
TypeSH
Feb 19, 2003 04:21 AM
Drinker
