I got OWNED: Lift Throttle Oversteer
Old May 22, 2003 | 09:23 PM
Understeer's Avatar
Default I got OWNED: Lift Throttle Oversteer
Wet conditions, going a little too fast in gradual turn down-hill that is a slight u curver similar to this shape, (
1/2 way through the turn, my car felt really stable, but then as I got past that 1/2 point, I felt the rear end to slide a bit, and then 0.001 seconds later, I the car oversteered and I found myself looking against traffic. Luckily the car that was behind me was quite a few lengths behind me and could avoid hitting me.
I didn't let off the gas, nor did I brake when I felt the rear end come out, so what did I do wrong? I tried to correct it, but obviously it didn't do anything and I did a 180 degree turn.
Luckily I didn't hit anything or damage my car, but it scared the **** out of me. The car stalled and I got the hell out of there really quickly to avoid any oncoming cars.
Old May 22, 2003 | 09:40 PM
P1mpSlap's Avatar
how fast were going and what gear were you in?
Also what do you drive? LS/GS or GSR?
seanb18c1's Avatar
I did the same thing, Turns out there was a nail in my rear passenger tire. The tire held it's shape due to it's stiff sidewall, but there was hardly any pressure in it. Dam those Nitto 450's!
Old May 22, 2003 | 10:03 PM
Understeer's Avatar
Default Re: (P1mpSlap)
3rd Gear in LS. Was not looking at speedo, so I do not recall speed.
Koni Yellows w/ H&R Sport Springs/BSQ + ITR 22mm Rear SwayBar and bunch of other stiffening bars.
Old May 22, 2003 | 10:22 PM
Volcom's Avatar
Default Re: (Understeer)
dumb question but maybe there was something on the road like sand or oil? I've been owned before also but it was on an autocross track.
Old May 22, 2003 | 11:25 PM
Calavera's Avatar
Default Re: (Volcom)
by correcting do you mean counter steer?
Old May 22, 2003 | 11:33 PM
dom93hatch's Avatar
Default Re: (Calavera)
OT: Maybe you should change your SN to Oversteer.
Old May 23, 2003 | 04:47 AM
JimBlake's Avatar
Default Re: I got OWNED: Lift Throttle Oversteer (Understeer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Understeer &raquo;</TD></TR><TR><TD CLASS="quote">... I didn't let off the gas, nor did I brake...</TD></TR></TABLE>
Then why did you call it 'lift throttle oversteer'??
Old May 23, 2003 | 05:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (dom93hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dom93hatch &raquo;</TD></TR><TR><TD CLASS="quote">OT: Maybe you should change your SN to Oversteer. </TD></TR></TABLE>
I was gonna say that
Old May 23, 2003 | 06:58 AM
Scary1109's Avatar
I didn't let off the gas, nor did I brake when I felt the rear end come out, so what did I do wrong? </TD></TR></TABLE>
if you didn't let off the gas, how did you have lift throttle oversteer? ??
Old May 23, 2003 | 07:11 AM
Understeer's Avatar
Default Re: I got OWNED: Lift Throttle Oversteer (Scary1109)
Good question, I do not even know the answer myself, perhaps the conditions were pretty bad I could not have done anything. I thought it was pretty odd that it slide and spun like that.
Yeah my name should be changed.
Old May 23, 2003 | 07:41 AM
Tweakmeister's Avatar
I usually ride it out if that happens.
I corrected once (snapped the wheel VERY fast) and got some grip.
If you feel it happening give it gas (this is important). Put on the brakes you will slide more.
Old May 23, 2003 | 08:54 AM
jaymar88's Avatar
Default Re: I got OWNED: Lift Throttle Oversteer (Tweakmeister)
couter steer and roll on the throttle. Kinda like *** dragging...
Old May 23, 2003 | 10:18 AM
SIISFLY's Avatar
i'm guessing your left tires went over the median line (the paint that divides the lanes) and slid you out. it's slicker than asphalt and moreso when it's wet.
Old May 23, 2003 | 10:53 AM
Cone's Avatar
the best thing to do in this situation is yank the E brake!!!
J/K
Best thing to do in this situation (I've been it many times) is to give it throttle to help bring the back into check...if not...ride it out and pray you don't hit anything.
-Andrew
Old May 23, 2003 | 11:37 AM
Heisdan's Avatar
I've been in that situation MANY MANY MANY TIMES.. when you enter a corner too quickly ur backend is coming out.. and unless you "blip" the throttle its going to continue to come around.. (then again I'm on stock suspension right now) .. i was hoping it wouldn't handle like that w/ some better suspension..
Rear end comes around first in the rain for my car.. (handles diff in dry weather.. all 4 tires same time)..
Final Statement: "You cannot predict what ur car is going to do in wet weather.. some puddles are bigger than others"
Old May 23, 2003 | 01:46 PM
Your Epitaph.'s Avatar
///M Power
Default Re: (Heisdan)
i got owned one time and unfortunatley i spun out and crashed....and i did blip the gas and i didnt use the brakes. the back end broke out to the right and i corrected it by turning the wheel right (into the skid) and tappin the gas.....i then did a 180 and hit the curb...damn stock suspension, tires and 14" steelies.
Old May 23, 2003 | 03:04 PM
Regular Series's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Understeer &raquo;</TD></TR><TR><TD CLASS="quote">Koni Yellows w/ H&R Sport Springs/BSQ + ITR 22mm Rear SwayBar and bunch of other stiffening bars.</TD></TR></TABLE>
There you go. That combination going downhill on curved, slippery surface will pull the ***-end of your car out.
Old May 23, 2003 | 04:46 PM
StinkyTofu's Avatar
How the heck did you do all that? Your name is understeer! J/k, i think its funny how you got owned by oversteer but your name is understeer. Glad you're alright.
EM2Tuner08
Honda Civic (2001 - 2005)
30
Jan 26, 2008 05:43 AM
civic89si666
Aug 26, 2006 07:45 PM
98cwitr
Sep 11, 2004 01:50 PM
