El reverse Indiglo gauges-----how to install??
Old May 22, 2003 | 09:21 PM
Shua derson's Avatar
Default El reverse Indiglo gauges-----how to install??
how do you get the dash and other crap off to install the gauges-->93 ls
Old May 22, 2003 | 10:17 PM
95 Gizzer
Guest
Posts: n/a
Default Re: El reverse Indiglo gauges-----how to install?? (93Integ)
You're supposed to put them on top of the gauges...and whatever you do, dont use superglue...
Old May 22, 2003 | 11:32 PM
GirlyGS-R's Avatar
you dont need to take off your dash. take off you top steering colum cover and your AC vents.
Old May 22, 2003 | 11:54 PM
xteg95's Avatar
Default Re: El reverse Indiglo gauges-----how to install?? (GirlyGS-R)
im sure http://www.team-integra.net has a section on how to install them, check there.
Old May 23, 2003 | 03:06 AM
ebelp's Avatar
Default Re: El reverse Indiglo gauges-----how to install?? (xintegra01)
Get a Haynes/Helms manual.
Old May 23, 2003 | 12:13 PM
spoon063's Avatar
take out the cluster and take it apart, put the gauges in with the wires runnign out the back or bottom, wire in teh power to a source (preferably into your diummer switch so they light up when your lights are turend on) i wouldnt use glue, if you cant get them to stay put then use very thin double sided tape, dont remove the needles of the gauges either theyre supposed to slide right over
mac_24_seven
May 2, 2018 10:12 AM
97civic123
Acura TL, RL & ZDX
Mar 17, 2010 05:30 PM
mritch02
Audio / Security / Video
Aug 30, 2004 07:04 PM
vannman
May 24, 2004 06:49 PM
