Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
question upon moving ABS from 92 GSR?
Old May 22, 2003 | 06:00 PM
crooked muffler's Avatar
Default question upon moving ABS from 92 GSR?
can i use my gsr master?
and just use some RS lines or some custum lines...id rather run RS ines
any info...
thanks
Old May 22, 2003 | 06:05 PM
Reid's Avatar
Global Moderator
Default Re: question upon moving ABS from 92 GSR? (anti-ricecake)
Try asking in the Integra forum.
Old May 22, 2003 | 07:34 PM
DB2-R81's Avatar
25 Year Member
Default Re: question upon moving ABS from 92 GSR? (Reid)
Yes you can, but one fitting on the new RS non ABS lines running from the master cylinder is smaller then the fitting on one of the old ABS lines. You need to cut the old ABS line remove the larger fitting off the line, then cut the new non ABS line remove the smaller fitting, transfer the larger fitting to the new RS non ABS line and re flare the line. Or use an adaptor good luck finding one, I had no success. You will also need a proportion valve and approximately 2 X 10” jumper lines to go from the new proportioning valve to the connector for the rear lines. If you need any pictures or more help let me know.
NotoriousJJE
Feb 16, 2012 10:41 AM
tam4511
Nov 22, 2011 06:19 AM
sjteg
Jul 25, 2009 07:21 PM
BoostinEJ1
May 6, 2006 05:50 PM
