How much air does an AEM c/a/i (intake) / K&N filter suck in?
Old May 22, 2003 | 04:30 PM
Fuster_Cluck's Avatar
Default How much air does an AEM c/a/i (intake) / K&N filter suck in?
Does anyone know? If it matters preferbly a B18C1 motor. The higher the RPM's the more air is sucked in right?
I have a hole in my splash guard and have placed a curved piece of metal around the backside of the filter/in front of the hole on the splash guard. I am just trying to get an idea if any (& how much) water is being sucked in when it rains. I think the shield does a good job, but still would like to know how much air is sucked in through a c/a/i filter
Old May 23, 2003 | 11:11 AM
PupaScoopa's Avatar
Default Re: How much air does an AEM c/a/i (intake) / K&N filter suck in? (Hybrid93Hatch)
It will suck in 1.8 liters of air every two revolutions. That's 720 liters/min at idle. If the filter is wet, you'll only get a few droplets of water in the air stream (and somewhat higher humidity).
If the filter is submerged, then you're SOL.
Old May 23, 2003 | 03:34 PM
civicVX's Avatar
you should just install aem's bypass valve then you don't have to worry about hydrolocking your motor.
Old May 23, 2003 | 03:38 PM
dfoxengr's Avatar
Default Re: How much air does an AEM c/a/i (PupaScoopa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PupaScoopa &raquo;</TD></TR><TR><TD CLASS="quote">It will suck in 1.8 liters of air every two revolutions. That's 720 liters/min at idle. If the filter is wet, you'll only get a few droplets of water in the air stream (and somewhat higher humidity).
If the filter is submerged, then you're SOL.</TD></TR></TABLE>
you cant measure air volume with a liquid measurement.
but there is no need to worry unless youre driving through 1 foot+ puddles
Old May 23, 2003 | 03:39 PM
dfoxengr's Avatar
plus thats still not right since the air is only needed at TDC for the combustion
sohc_freak
10
Jul 10, 2006 11:56 AM
green91
May 18, 2005 08:42 AM
Vtecfool
Jun 4, 2003 09:23 PM
