Crx suspension question...
Old May 22, 2003 | 01:57 PM
IamVtec's Avatar
Default Crx suspension question...
There was a post on here about Accord shocks on a Crx . And they said that handle was great. I was looking for that post and couldnt find it. But what yr was the accord shocks? If no one remembers that post. Will an 82-85 accord shocks fit on a 88-91 crx? THanks in advance.
Old May 22, 2003 | 02:00 PM
Outsane's Avatar
Default Re: Crx suspension question... (Full Throttle EF)
it was an 89 acord shock..
I just installed ome bilstiens, and I asked if there were any advangates to doing this and after the tech took some measurements, he called back and told me there were no advantages on using the accord shocks..
Old May 22, 2003 | 02:19 PM
Crxer's Avatar
I think the post was "BEST MOD EVER" or something like that. And the person put 89 accord bilstein struts in and said he gained about 1-2 inches of travel or something like that. Sounds like a good mod to me, im planning on doing it later this summer.
Old May 22, 2003 | 02:20 PM
DJ_SaNdOz's Avatar
Default Re: Crx suspension question... (Outsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">it was an 89 acord shock..
I just installed ome bilstiens, and I asked if there were any advangates to doing this and after the tech took some measurements, he called back and told me there were no advantages on using the accord shocks..</TD></TR></TABLE>
did the tech not concur that you would gain extra shock travel, or did he not look/realize? or, is nothing gained? just curious.
Old May 22, 2003 | 02:28 PM
Outsane's Avatar
Default Re: Crx suspension question... (DJ_SaNdOz)
He measured the shock bodies, and they were the same length..
so there would be no gain in travel..
Old May 23, 2003 | 08:57 AM
Xian's Avatar
I may be mis-remembering but I thought that in the original thread it mentioned the mounting point for the damper fork being higher up the shock body. If you have coil overs this would allow you to adjust them "higher" and still retain the same ride height.
I didn't look for the thread... this is just from memory so maybe I'm wrong...
Old May 23, 2003 | 09:01 AM
RicedREX's Avatar
Default Re: Crx suspension question... (Xian)
what about 90-93 accords?
Old May 23, 2003 | 09:08 AM
Xian's Avatar
Default Re: Crx suspension question... (RicedREX)
here's the thread that I was thinking of... the part about Accord struts and changing their mount piitn is about halfway down... hth.
https://honda-tech.com/zerothread?id=378981
EL-Driver
Dec 24, 2014 05:42 AM
B6teen
Jan 7, 2007 01:23 AM
GSRCRXsi
May 27, 2004 07:39 PM
crexer
Jul 13, 2003 10:12 PM
