Type-S piston question
Old May 22, 2003 | 01:34 PM
Twenty36_1's Avatar
Default Type-S piston question
I have searched for this but I only found more questions. First, Are the cylinders Nikasil coated? (I am pretty sure, but after reading and archived post I am unsure). Second, Since the type-s oversize pistons are larger than stock you would need to bore the cylinders right? BUT isn't that bad for the cylinder walls (FRM)? From owning dirt bikes I know if the cylinders are Nikasil coated then boring it would remove the Nikasil and make it more likely to gall. Does anyone have type-s pistons for an extended perion of time (>75,000 miles)? Sorry for the newbie questions and TIA.
Old May 22, 2003 | 01:51 PM
2kflamedlude's Avatar
Dont get the over size one then
Old May 22, 2003 | 01:53 PM
HotWheelz's Avatar
Default Re: (2kflamedlude)
i got mine bored, you need 3 stones and a special lubriacant... because frm isn't a polish finished more like a dull finish... looks like a wetsanded clearcoat.. not shinny...
my engine shop could do it so yours should be able to aswell.. call your manchine shop to check into it .. it can be done.
Old May 22, 2003 | 02:59 PM
Twenty36_1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kflamedlude &raquo;</TD></TR><TR><TD CLASS="quote">Dont get the over size one then</TD></TR></TABLE>
I agree but I was just wondering why they would make them , but not be able to use them.
Old May 22, 2003 | 03:01 PM
Twenty36_1's Avatar
Default Re: (HotWheelz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotWheelz &raquo;</TD></TR><TR><TD CLASS="quote">i got mine bored, you need 3 stones and a special lubriacant... because frm isn't a polish finished more like a dull finish... looks like a wetsanded clearcoat.. not shinny...
my engine shop could do it so yours should be able to aswell.. call your manchine shop to check into it .. it can be done.</TD></TR></TABLE>
So it is basically just a little more agressive whoning rather than boring, right? Sorry for the questions.
Oh yeah, how many miles do you have since this?
eddie7978
Engine Machining & Assembly
May 12, 2017 09:36 PM
BoBo Racing
Aug 30, 2006 09:36 AM
Rghrob
Sep 6, 2003 12:07 AM
Greyout
May 8, 2003 10:38 AM
austrian type-R
Sep 15, 2002 10:52 PM
