Apexi N1 Silencer = Performance? -
Old May 22, 2003 | 01:05 PM
redlinex's Avatar
Default Apexi N1 Silencer = Performance? -
hrm... just wondering. i have a 98 gs-r and if i were to purchase the apexi n1 exhaust system will i need a different cat? also i heard that if you use the silencer it drops the maximum performance of the n1 is capable of around (5 to 15% power cutdown)? true? thx.
Old May 22, 2003 | 01:10 PM
Mark's Avatar
*Bounty Hunter*
Default Re: Apexi N1 Silencer = Performance? - (redlinex)
The silencer killsthe performance. I noticed that after installing the silencer, my car did not pull as hard as it did with it out. (97' GSR)
Old May 22, 2003 | 01:44 PM
Link0's Avatar
Default Re: Apexi N1 Silencer = Performance? - (94BlackCivicEX)
I have an N1, and when I put the silencer I really don't feel a difference in power. Dyno numbers might prove me wrong but on my car I really like the silencer in.
Old May 22, 2003 | 01:48 PM
WiggiE's Avatar
New User
Default Re: Apexi N1 Silencer = Performance? - (Link0)
No, you don't need a different cat. It will bolt right up. As far as the silencer goes, yes you will lose HP. How much, well that is disputed, but many say you lose almost as much as you gained from the exhaust. So is it worth it to run around all the time with it, no. But it is a nice thing to have for long trips, etc.
Old May 22, 2003 | 01:50 PM
Kelvin96GSR's Avatar
25 Year Member
Default Re: Apexi N1 Silencer = Performance? - (WiggiE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiggiE &raquo;</TD></TR><TR><TD CLASS="quote">No, you don't need a different cat. It will bolt right up. As far as the silencer goes, yes you will lose HP. How much, well that is disputed, but many say you lose almost as much as you gained from the exhaust. So is it worth it to run around all the time with it, no. But it is a nice thing to have for long trips, etc.</TD></TR></TABLE>
Old May 22, 2003 | 03:35 PM
incubus's Avatar
Default Re: Apexi N1 Silencer = Performance? - (Kelvin96GSR)
typically silencers are going to increase backpressure which will decrease high end HP but will increase low end torque.
I had an N1 w/ silencer on my old accord and I couldnt notice much of a difference on or off in performance.
Old May 22, 2003 | 05:51 PM
gsrRIP's Avatar
Went to the track wit my silencer on, I FORGOT, LOL. Anyway 1st run 16.1 with the silencer. 2nd Run 15.7 without.
Old May 22, 2003 | 06:08 PM
Mark's Avatar
*Bounty Hunter*
Default Re: (gsrRIP)
.4 sec diff without a silencer...yowieeeee lol
N1 w/out silencer
Old May 22, 2003 | 07:15 PM
WiggiE's Avatar
New User
Default Re: (94BlackCivicEX)
Wow, I knew there was quite a difference but not 4/10ths of a second. That's a crapload.
Old May 22, 2003 | 07:30 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94BlackCivicEX &raquo;</TD></TR><TR><TD CLASS="quote">The silencer killsthe performance. I noticed that after installing the silencer, my car did not pull as hard as it did with it out. (97' GSR)</TD></TR></TABLE>
hell yeah it does. I only use mine on my Tanabe racing medallion on road trips.
Old Jun 1, 2003 | 05:58 PM
rocket3004's Avatar
Default Re: Apexi N1 Silencer = Performance? - (P1mpSlap)
Are you sure that it makes that big of a difference or was it that you had a better run with the silencer out?
Old Jun 1, 2003 | 06:27 PM
StyleTEG's Avatar
Default Re: Apexi N1 Silencer = Performance? - (rocket3004)
It depends on the rest of your engine setup.
I saw a dyno that actually increased performance with the silencer in. Now obviously the silencer really doesn't increase performance, it was more of incosistances in dyno runs, but if your engine isn't creating enough HP to take advantage of your current exhaust system, a silencer isn't going to make much of a difference.
Old Jun 1, 2003 | 06:49 PM
Link0's Avatar
Default Re: Apexi N1 Silencer = Performance? - (incubus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incubus &raquo;</TD></TR><TR><TD CLASS="quote">typically silencers are going to increase back pressure which will decrease high end HP but will increase low end torque.
I had an N1 w/ silencer on my old accord and I couldnt notice much of a difference on or off in performance. </TD></TR></TABLE>
This one sums it up the best. After I read this post I paid really close attention to how my car performed with the silencer in and out. The reason I dont mind it for daily driving is it does increase the mid to low end torque. It however does take a nice chunk of power post vtec.
My vote = In for daily driving (unless you are planning a wild drive) and long road trips. Out for racing or anytime you want max power.
Old Jun 1, 2003 | 06:55 PM
slimbo's Avatar
well... my **** dyno tells me the power has dropped off through the whole rev range with a silencer in.
doughy throttle response at low rpms, nowhere near as much action at high rpms.
but then, this could be a touch of the placebo effect, i'd be interested to try it out on a dyno...
Old Jun 2, 2003 | 05:26 AM
StyleTEG's Avatar
Default Re: Apexi N1 Silencer = Performance? - (slimbo)
Butt Dyno
The red is with the silencer in. Don't put much faith in what your *** is telling you about the performance of your car.
LudeLooker
Apr 18, 2004 09:11 PM
slowman
21
May 26, 2003 08:26 PM
superduperman
Mar 29, 2003 10:15 PM
Mark
Mar 2, 2003 03:46 PM
clean
Aug 25, 2002 12:31 AM
