A/C is pissing me off
Old May 22, 2003 | 10:04 AM
DrunkNRacer's Avatar
Default Direction Problem with A/C
94 accord lx
a/c varies from time to time.. I push on the [head/foot] blower.. and it just blows to feet.. than i try to switch it back to just [head] and it doesnt work.. seems like a sensor malfunction or something.. anyone know the remedy??
Modified by G-villeRacer at 5:26 PM 5/22/2003
Old May 22, 2003 | 01:23 PM
Default Re: A/C is pissing me off (G-villeRacer)
somebody has to have had the similiar problem
Old May 22, 2003 | 03:51 PM
Chiovnidca's Avatar
If all your fuses are good, there may be a problem with the mode control motor on the left side of the heater box.
Old May 23, 2003 | 06:50 AM
Default Re: A/C is pissing me off (Chiovnidca)
is that the little bastard under the glovebox.. because it tends to make a clicking noise from the fan..
Old May 23, 2003 | 11:13 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-villeRacer &raquo;</TD></TR><TR><TD CLASS="quote">is that the little bastard under the glovebox.. because it tends to make a clicking noise from the fan..</TD></TR></TABLE>
Nope, left side of the heater box. Above the gas pedal.
Old May 23, 2003 | 11:30 AM
and how do you suppose i check it?
Old May 23, 2003 | 11:58 AM
sidwin's Avatar
New User
My wife's honda accord 94 with 208,000 miles on it does the same exact thing. I ended up just leaving it alone and let the a/c blow to my face. You have to keep on messing with the buttons to get it to go where u want it to. SUCKS!
Good luck,
Sid
Old May 23, 2003 | 12:15 PM
twkdCD595's Avatar
Default Re: (sidwin)
I wont have to worry but mine use to work like a champ...
Old May 23, 2003 | 01:25 PM
YeuEmMaiMai's Avatar
Default Re: Direction Problem with A/C (G-villeRacer)
there is a problem with the 94/95 accords where the solder joints where crappy on some of the circuit boards for the control unit. depending on how good youare with a soldering iron, you can try to clean up some of the joints.
Old May 23, 2003 | 01:29 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G-villeRacer &raquo;</TD></TR><TR><TD CLASS="quote">and how do you suppose i check it?</TD></TR></TABLE>
You can see if it moves through it's full range of motion. Does it move at all? Does any of the linkage bind?
Boost Addict
Aug 3, 2018 10:12 PM
lilo_goki
Oct 7, 2008 01:18 PM
RyanJC
14
Dec 27, 2007 02:26 PM
mhouston
Dec 11, 2003 05:22 AM
chi@1001
Mar 7, 2002 03:16 AM
