Integra back seat out??
I am currently takin re-carpeting the car, but i cant seem to find out how to take you the back seat, so I can take the old carpet out. Is there bolts somewhere hidden? Thanks in advance
You have to remove that 1 bolt in middle, lower back that holds the bottom of the seat down.
Then get some needle nose pliers and slide the seat over just a tad, so you can see the clip that holds the actual back portion of the seat in. Pull those out on each side.
Then you'll be able to push 1/2 of the seat away from the middle portion that holdes the seats together. So push outwards. Once you've removed the back portion you'll see how it goes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap »</TD></TR><TR><TD CLASS="quote">You have to remove that 1 bolt in middle, lower back that holds the bottom of the seat down.
the clips, is there like 2 little metal things goin through each clip, in the center, where the two seats meet? or am i looking at the wrong part?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vince10984 »</TD></TR><TR><TD CLASS="quote">
the clips, is there like 2 little metal things goin through each clip, in the center, where the two seats meet? or am i looking at the wrong part?</TD></TR></TABLE>
It's a little plastic clip on the side of the seat where the lower fold is (near the back). It's like a little "C" plastic clip that wraps around the bar.
