F/S... short block LS/VTEC
LS block 85mm bore
GSR internals (crank,girdle,windage tray,oil pan)
Eagle Rods
JE 11:1 pistons
Block guard
Type R oil pump
(only needs water pump)
Balanced/Blueprinted JG Pro Series II
Motor has 2K miles on it. Have milage for when installed and when removed. Took it out due to head gasket problems. Was using Cometic HG LS/VTEC (which at the time were all defective) May-Sept 02. Gave up on spending money on it.
Block was checked for warp...2 times by 2 different shops...Wasted my damn money!!! Both times were flat. Head was checked with block both times. All fine.
Motor was never taken to the track and never ran beyond 8K RPM's. I never even go to run it at the track!! You know how pissed off that makes me!!
Reason for selling... Want to get married and liquidating all un-needed parts/motors. need money to pay for engagement ring!!
Price... $2000 firm. Motor is in perfect shape. I will try to get pics shortly
Eagle Rods
JE 11:1 pistons
Block guard
Type R oil pump
wrx-killer-Sti-eater
Oct 17, 2009 07:35 AM
Ran4it2
Feb 10, 2009 12:18 PM
