Huge Honda Garage sale
I have tons of **** piling up in the garage and didnt notice how much **** i actually had. All prices are set pretty low and also pretty firm on the prices. NO LOWBALLERS. please dont waste my time either. Best way to contact me is on my cell Brian 757-560-8680 , i only check threads and pms late at night. All Prices plus shipping. Thanks.
set of 4 obd0 b16 injectors rebuilt 1 yr ago $35
88-91 unused spare tire and jack $25
88-91 2 sets of lower controll arms $20 a set
90-93 integra clutch cable $20
JDM B16 stock header and downpipe / wheat sheild $50
90-91 CRX tails all 3 peices $50
88-91 D series ac compressor 1 year old $15
obd0 pm5 ecu $20
obd0 pm9 ecu $20
88-91 shift linkage $15
B series fuel line ( from filter to rail ) $5
90-93 integra complete shift linkage , shifter , busshings , the whole nine.***SOLD***
88-91 civic rear view mirror black $10
94 LS exhaust manifold no downpipe $15
optimus 200 watt 2 chanel amp $25
88-91 front crossmember professionally cut and welded for b series swap $40
90-91 CRX si front seats driverside rip was sewn but they are in very good condition $75
88-91 D-series Front transmission mount (brand new) $15
92-95 Front upper strut bar ... good condition $40
2 sets of 88-91 upper controll arms good ball joints $30 a set
94 integra rear mount bracket $15
obd1 LS distributor good condition , new cap $50
90-91 Civic front bumper and support $50
89-91 Front and rear stock strut/spring assemblies struts have 9k on them ... good condition $50 for all.
88-91 5 spd front hubs $40 for the pair
2 88-91 d series manual starters $25 a peice
90-91 civic gauge cluster cover w/ switches $25
88-89 civic si cluster ( clean ) $60
90-91 civic si cluster ( needs to be cleaned) $50
2 88-91 stock air box ... $10 a peice
95 integra clutch and pressure plate ( tons of meat left ) $40
86-89 Nissan Maxima KYB GR-2 rear shocks ( BRAND NEW ) $50 for pair
88-91 civic front trims peice under headlights , very good condition. $35
88-91 rear seats top and bottom grey vinyl good condition $30
95 integra intermideate shaft $20
95 LS ecu $60
d series pressure plates and flywheels $10 a peice
88-91 rear hatch cover brown $10
obd1 ls injectors $30 a set of 4
92-95 del sol driver door panel $20
88-91 wheel well liners $5 a peice
88-91 civic hatch stock rear wing blue $20
92-95 civic 2dr stock tails $50
92-95 civic 2 dr stock corners $10
88 d15b2 , bad head. ***SOLD***
Modified by PoS_hYbRiD at 6:33 PM 5/22/2003
Modified by PoS_hYbRiD at 7:41 PM 5/22/2003
obd0 pm5 ecu $20
obd0 pm9 ecu $20
95 LS ecu $60
i actually have a 88 crx si rear setup .... it is complete. sorry i didnt specify. pretty sure it will fit because you have everything but it is different than 89-91 , so you might have to check.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoS_hYbRiD »</TD></TR><TR><TD CLASS="quote">i actually have a 88 crx si rear setup .... it is complete. sorry i didnt specify. pretty sure it will fit because you have everything but it is different than 89-91 , so you might have to check. </TD></TR></TABLE>
Yeah, 88 are different than 89+. Thanks anyway.
