LSVtec build, what do i do now what parts will i need?? Just got my Block Today.
Guest
Posts: n/a
I got my block, 98 B18B, have my head from other swap. What do i need to do to mate the two, i know that I need a oil line, and that i have to use the LS head gasket. I want to get some ARP rod bolts, bu ti dont know where ot get them or how much they cost.
Can i just remove the LS head, install the oil line, use the LS gasket and roll with it or what??
Thanks if there is anything that i missed please tell me.
Guest
Posts: n/a
The search suxs i cant find anything about how to build it. Please help id like ot be on my way doing this and gettign the parts that i need by this weekend
Okay, I'll try to help. There's two ways to do this.
#1. The old way. You can follow C-Speed's buildup. Basically, you have to redrill the head for the dowel pins and tap off one of the oil fittings.
#2. The bolt in buildup. Get the LS/VTEC kit from Paul_Vang https://honda-tech.com/zerothread?id=420826
And if you don't want to tee off the block, you can get the oil feed adapter from GE.
Good luck!
Good luck!
dame-ningen
24
Jun 15, 2009 07:08 PM
daddycivic
Jul 20, 2004 04:06 PM
