Fluidyne Radiator for 90 CRX Si with B16a?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiMhist »</TD></TR><TR><TD CLASS="quote">Will the half size Fluidyne for a 90 CRX Si be sufficient for a B16a equipped car?</TD></TR></TABLE>
Yes it will be. So then you will be getting the half sized for the CRX from fluidyne correct? Caue it should be a thicker radiator as well.
FYI
I have a CRX HF with a B16, and I didn't change the radiator. It's almost been a year, and I've never had any problems.
Probably not what your looking for but this site sells double thick replacement Radiators for pretty cheap, I've heard the product is good...
http://www.absoluteradiator.co...rod=9
I've got the full size fluidyne radiator in my car and I had no fitment problems even still has the fan, I'm not sure about with the B16 though but from I've read it'll fit just fine and there about the same size
you planning on going with some crazy Turbo header or something?
Sorry I didn't reply sooner but I'm in the middle of moving. I don't have very much room in between the fan and header so I figured I would use a half size just in case I need room at a later date.
Thanks for the replies.
hatchinprogress
10
Dec 29, 2005 07:37 AM
b18-c-rx
16
Jan 17, 2005 11:40 AM
