All motor monster: tuneing high compression z6
Old May 21, 2003 | 09:41 PM
spun Vtec's Avatar
Default All motor monster: tuneing high compression z6
I recently swaped a sohc vtec motor into my civic hatch before i put it in i built it (12.1:1 cr &shot peened rods)(list below) and now that its broken in i am happy about the results but feel it has alot more potential. I have never tuned a car before and i know it is a delicate process but i don't really know of ways of tuneing it myself without the use of a dyno (closest one is almost 3 hours away).
I have an air/fuel guage along with a fpr (fuel pressure regulator) and i know there not that accurate but i seem to have my car running ok as far as that goes. When im full throttle im most in the green (rich) and one or 2 LED's in stoich which i guess thats about where i need to be.
On the ignition side of things i am at stock timeing and will be playing with it a little after i have some info on what type of fuel to run.
here's my setup:
rebuilt d16z6 (sohc vtec) longblock
d16a1 pistons (12.1:1 cr)
arp connecting rod bolts
felpro gasket kit
d16a6 intake manifold
d16z6 fuel rail
d16y8 head gasket
adj fuel pressure regulator
full obd1 conversion
p28 ecu
JG throttle body
AEM cold air intake
airmass hedder
2.25 custom bent exhaust
revolution muffler
M&R short throw shifter
energy suspension shifter bushing kit
underdrive pully
centerforce dual friction clutch
si trans (soon to swap zc trans w/intermediate shaft)
iI don't have a clue on octane that i should be running i guess maybe around 110 if i advanced my timeing? How far can i go and what else can i do besides get an AFC to make it run a little better i know i can get it running better than its running now (mid to low 15's) without doing much i just need some direction i guess. ha
Any advice would be appreciated.
Thanks -Larry
Old May 21, 2003 | 10:26 PM
.RTErnie's Avatar
Default Re: All motor monster: tuneing high compression z6 (spun Vtec)
find another O2 bung for wideband...and hit the dyno!
Old May 22, 2003 | 09:47 AM
Cltchbrnr's Avatar
You need a better way to tune (I recommend hondata or EMS) however chipping your ecu and vafc should work ok for it. Goodluck.
Old May 22, 2003 | 09:54 AM
1_bad_EF's Avatar
U need to get a Hondata setup. The ignition timing tuning is what will make or break high compression motors. factory Honda ignition timing maps are optimized for stock motors and cams.
If, under load, you hear a what sounds like a heatsheild rattling, its not the heatsheild, it DETONATION. thats BAD!
Old May 22, 2003 | 12:49 PM
dfoxengr's Avatar
Default Re: All motor monster: tuneing high compression z6 (1_bad_EF)
thats an all motor "monster". hmmm not quite my idea...but u really need to dyno tune it. and drop your factory exhaust. and no theres no way in hell you need 110 octane, lol. i have no clue where you got that idea from, but youll be 300% safe on 93 oct.
Old May 24, 2003 | 09:54 AM
spun Vtec's Avatar
Default Re: All motor monster: tuneing high compression z6 (hybridvteceg)
i dont have stock exhaust i have custom bent 2.25" to a revolution muffler and you think 12.1 to 1 compression is ok with 93? i dont really think so. How much $$ am i looking at for a hondata setup?
Old May 24, 2003 | 04:48 PM
daniboy4nspd's Avatar
wat octane gas are u running in it right now?
Old May 24, 2003 | 10:30 PM
spun Vtec's Avatar
Default Re: All motor monster: tuneing high compression z6 (daniboy4nspd)
94 octain but i think i should be running higher
Old May 25, 2003 | 04:49 AM
sauceman's Avatar
Nah, 94 should be plenty ok with 12:1. You need good tuning. Make sure you stay on the rich side and you will be okay.
Old May 25, 2003 | 07:52 AM
pills_PMD's Avatar
i run 12.3:1 on 93 octane tuned with hondata on an lsvtec in a del sol..
get hondata.. it's the only way
Old May 25, 2003 | 08:30 AM
spun Vtec's Avatar
Default Re: (pills_PMD)
how much is a obd1 hondata setup? what options do i need when i get it>?
Old May 25, 2003 | 12:09 PM
yaya's Avatar
when a z6 is a monster ill put mine back in my civic
jk
damn nice setup
Old May 25, 2003 | 06:36 PM
spun Vtec's Avatar
Default Re: All motor monster: tuneing high compression z6 (yayaRl337)
thanks bump
Old May 26, 2003 | 10:44 PM
spun Vtec's Avatar
bump
Old May 27, 2003 | 08:26 AM
spun Vtec's Avatar
Default Re: (spun Vtec)
bump
FormulaIntegra
Jan 1, 2018 10:17 AM
spun Vtec
12
May 18, 2004 05:52 AM
spun Vtec
15
May 26, 2003 10:43 PM
spun Vtec
13
Dec 19, 2002 04:21 AM
spun Vtec
10
Dec 18, 2002 03:43 PM
