Just got my Axxis Ultimates - Thanks Andie! Minor install issues...
Old May 21, 2003 | 07:26 PM
Lang's Avatar
Default Just got my Axxis Ultimates - Thanks Andie! Minor install issues...
After several Honda-Tech member recommendations, I picked up a set of Axxis Ultimate front brake pads and 2L of ATE Super Blue Brake Fluid from Andie at http://www.cobaltfriction.com. Great guy to work with, H-T members get a discount, too.
Just got them installed today, the Helms Service Manual (and a friend, thanx Darren!) came in handy again. I had a minor issue with getting the piston pressed back in, since the new brake pads were thicker than the existing. I made a very *messy* mistake...We tried pressing the piston back in with our hands, but that didn't work. I then unscrewed the bleeder valve and tried pressing on the brake. Big mistake! The piston on the other side of the car came popping out!!! Fluid everywhere, ouch. The other one came out, too.
The piston boot did not look damaged, so we reused it. It was kind of a pain to get the piston boot seated back in, though. The actual pad removal and replacement was the easiest part, it's only fastened in by a single 14mm bolt. Had to use a breaker bar for those.
The pads feel pretty good. My stock fluid was toast, and the stock pads were crumbling and had rough, uneven spots on them. I need to bed the new ones in properly and take them to the track, so I can't say yet how much better they are compared to stock setup.
ATE Superblue made in Germany=must be good
Here's pix of the box, in case you were wondering.
Andie included this bed-in procedure:
Done.
oops.
Modified by Lang at 10:37 PM 5/21/2003
Old May 21, 2003 | 07:42 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Search before install next time!
Old May 21, 2003 | 07:47 PM
py1188's Avatar
Default Re: (Rguy)
Hey if you're from Chicago, why the hell do you have Cardinals memorabilia
j/k...trader
Give us a review on the pads down the road
Old May 21, 2003 | 09:26 PM
RockstarJR's Avatar
Default Re: Just got my Axxis Ultimates - Thanks Andie! Minor install issues... (Lang)
Andy
Awesome guy! Awesome Pads!
Old May 21, 2003 | 10:02 PM
Ekizzle's Avatar
Default Re: Just got my Axxis Ultimates - Thanks Andie! Minor install issues... (ITRChris)
Nice JOb !
Old May 21, 2003 | 10:52 PM
VTHokie's Avatar
Default Re: Just got my Axxis Ultimates - Thanks Andie! Minor install issues... (AWD 18T)
Cobalt
Old May 21, 2003 | 11:52 PM
Night_Minx
Guest
Posts: n/a
By the color of your calipers, I knew right away this would end up in disaster.
No suprises here.
Old May 22, 2003 | 01:43 AM
zer0zer0 TypeR's Avatar
Default Re: Just got my Axxis Ultimates - Thanks Andie! Minor install issues... (Night_Minx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Night_Minx &raquo;</TD></TR><TR><TD CLASS="quote">By the color of your calipers, I knew right away this would end up in disaster.
No suprises here.
BWWAAAAHAHAHAHAHAHAHAHA, it's late and i found that very amusing
Old May 22, 2003 | 02:24 AM
nEoMuGen's Avatar
Default Re: Just got my Axxis Ultimates - Thanks Andie! Minor install issues... (zer0zer0 TypeR)
Invest for a C-Clamp.
Old May 22, 2003 | 06:03 AM
EleanoR's Avatar
Default Re: Just got my Axxis Ultimates - Thanks Andie! Minor install issues... (nEoMuGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nEoMuGen &raquo;</TD></TR><TR><TD CLASS="quote">Invest for a C-Clamp.</TD></TR></TABLE>
^ he hit the nail on the head. You need a C clamp to compress the piston back into the caliper. You can get these at any local hardware store. I always use one of the brake pads that i just took off to put on top of the piston inside the caliper and use the C clamp on it and it works like a charm every time. Make sure to pop open your master cylinder before compressing the piston as you are pushing fluid throughout the system.
mike
Old May 22, 2003 | 06:20 AM
mstewar's Avatar
Default Re: (py1188)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py1188 &raquo;</TD></TR><TR><TD CLASS="quote">Hey if you're from Chicago, why the hell do you have Cardinals memorabilia </TD></TR></TABLE>
because he must like a consistently winning team..
but yeah, pop open the master cylinder and soak up the excess next time..
thanks for supporting an expo sponsor..
TsunamiZC's Avatar
Default Re: Just got my Axxis Ultimates - Thanks Andie! Minor install issues... (EleanoR)
please paint those calipers flat black
Old May 22, 2003 | 06:24 AM
Mullet_SyTy's Avatar
just leave the calipers on the car and get a flathead screwdriver or small flatbar between the pad and rotor and force them apart (you can even crack the bleader screw open to make it much easier and not force crap back up throughout the system). Pry until the piston goes all the way back in. If you do one side at a time you will not experience the fun mess of a piston coming out of the caliper. I hope you replaced the piston seal or you might have a few problems with leak or a frozen piston later. Notice I said "might".
Of course the snappy go fast red paint might peel off because of the brake fluid.
Old May 22, 2003 | 06:59 AM
Floyd's Avatar
Default Re: Just got my Axxis Ultimates - Thanks Andie! Minor install issues... (98_ITR#396)
I guess I've always done mine one side at a time, but that would totally make sense that compressing one piston would force the other to pop out. It didn't have anything to do with the bleed screws though.
And opening the bleed screw of the caliper you are compressing makes sense too. Then you top off the reservoir when you are done and you've done a quick bleed at the same time.
I'm not sure if a screwdriver is such a good idea here. I'm sure the rotor can handle it, but it just doesn't sound right. I find that a sliding clamp does the job nicely before you even unbolt the caliper and swing it up.
Old May 22, 2003 | 07:59 AM
ScaleExtric's Avatar
Default Re: Just got my Axxis Ultimates - Thanks Andie! Minor install issues... (VTHokie)
Damn..Im still waiting for mine
szczerbanator
May 26, 2009 05:06 PM
dr_spock
Honda Civic (2001 - 2005)
Sep 20, 2008 10:22 PM
CapYoda
11
Apr 23, 2005 03:08 PM
89JDMcrx
11
Oct 18, 2004 10:51 AM
el_Presidente
Feb 12, 2003 09:08 PM
