Setting oil pressure correctly for h22a (race motor, allmotor cams) how do you shim it ?
Old May 21, 2003 | 06:26 PM
HotWheelz's Avatar
Default Setting oil pressure correctly for h22a (race motor, allmotor cams) how do you shim it ?
I'm going to be assembling my bottom-end this week-end and i'm going to install my prodrive oilpump gears (hopefully it's worthy purchase) and wanted to know what should be a good shimmed oil pressure to aim for ?
from what i've gathered it's recommended to have 10psi per 1000rpm ? the cams are known to provide power until 8000rpm or so before falling (crower stage 3's) just wanted to know what oilpressure i should be aiming for and how much a shim is equal to in psi, or how think goes to the ratio for it, so i don't under or over shim it ?
any help is SERIOUSLY appreciated! (Comments/suggestions also welcomed)
-G
Old May 21, 2003 | 07:07 PM
Suprdave's Avatar
Default Re: Setting oil pressure correctly for h22a (race motor, allmotor cams) how do you shim it ? (HotWhe
Why don't you just run it as-is and see where your at? What bearing clearances did you use on the main\rods and what oil do you plan on running?
Suprdave
Old May 22, 2003 | 11:15 AM
HotWheelz's Avatar
all factory new bearins from honda, to matching crank, and block, stock specs new, oil most likely 5W-30, minaral to break in, then full syntec after a while (castrol) popular and good in canada.....
running some large cams, and extended rpm that's why....
Old May 25, 2003 | 07:58 AM
indomotor's Avatar
You can increase oil pressure by using a smaller oil filter....
Old May 25, 2003 | 12:40 PM
K20  EG's Avatar
isnt there a smegma valve that lets you adjust it on that motor
Old May 25, 2003 | 01:01 PM
simple4012's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20---Vtec &raquo;</TD></TR><TR><TD CLASS="quote">isnt there a smegma valve that lets you adjust it on that motor</TD></TR></TABLE>
im inetrested in yuor water pump but your pm is off.
93itbh22hatch
34
Feb 7, 2011 02:14 PM
03k24
Nov 7, 2010 07:09 AM
delslowtofast
Oct 15, 2007 09:27 PM
1dopesi
Feb 8, 2007 05:28 PM
96MidoriHatch
Sep 12, 2004 08:18 PM
