Is a Type R throttle body compatible with the GSR intake manifold?
Old May 21, 2003 | 05:45 PM
SSBlueDC2's Avatar
Default Is a Type R throttle body compatible with the GSR intake manifold?
Might be a stupid question, but just as the topic states. My homie is selling his Type R throttle body for like 100 bucks, so I just wanna know if it will work. Thanks.
Old May 22, 2003 | 02:17 AM
akhom's Avatar
Default Re: Is a Type R throttle body compatible with the GSR intake manifold? (SSBlueDC2)
Sure it will bolt up, but where you going to put the throttle cable? Plugs in but no play. Throttle cable needs the bracket the will not bot on to ITR TB.
Old May 22, 2003 | 06:10 AM
split's Avatar
you also need a b16 or type-r throttle cable unless you plan in unwinding yours.
correct me if I'm wrong.
Old May 22, 2003 | 08:27 AM
neo1z's Avatar
Default Re: (split)
Okay, first, 100$ for that TB is a ridiculously good deal. I sold my GSR TB for 105. Is he giving you sensors?
Well either way - good deal.
I would either:
a) Buy a Skunk2 Manifold now if you have the cash. The ITR TB matches PERFECT (62mm to 62mm) with the Skunk2 Manifold. Then youre just an ITR Throttle Cable and Bracket away from a gorgeous install (my setup ).
b) Buy a Skunk2 Manifold as soon as you can, and wait to install the ITR TB - see above once purchased.
Old May 22, 2003 | 02:08 PM
Comp97GSR's Avatar
Default Re: (neo1z)
Are you sure about 62-62mm match? My S2 manifold is 64mm.
Old May 25, 2003 | 05:10 PM
youngvedder's Avatar
what is the size difference between a GSR & ITR throttle body? what is the size diff?
Thanks.
YV
Old May 25, 2003 | 06:39 PM
thegrinch's Avatar
here is what you do.
Take the ITR throttlebody pulley off and put the GSR's pulley in its place..... make sure you load the spring. It will work fine I did it for a friend. no problems
Old Jun 2, 2003 | 09:26 PM
bearingburner's Avatar
okay i have the same prob with it. just got this today. i used the gs-r throttle cable, switched pulleys, now where does the bracket mount to? thnaks for the help if you can guys
Old Aug 3, 2004 | 10:54 PM
albsgsr's Avatar
Default Re: Is a Type R throttle body compatible with the GSR intake manifold? (bearingburner)
I know this is an old post, but i'm havin similar issues mounting the throttle cable. If it is possible, please post how.
thanx
Drzhope89
May 17, 2017 12:09 PM
YangFlavor
Mar 25, 2010 09:55 AM
autoxthis
Aug 9, 2008 07:48 PM
autoxthis
Aug 9, 2008 09:18 AM
I B Z
May 21, 2003 01:44 AM
