94.9% duty on injectors too high??? and how to fix!!
Old May 21, 2003 | 05:04 PM
jansenrw's Avatar
Default 94.9% duty on injectors too high??? and how to fix!!
as titile states.. please help!!!
Will a sard fuel pressure regulator be sufficient or do I need to upgrade pump as well????
Old May 21, 2003 | 05:09 PM
Big Phat R's Avatar
Default Re: 94.9% duty on injectors too high??? and how to fix!! (jansenrw)
No you need bigger injectors with higher flow rate/min.
Old May 21, 2003 | 05:13 PM
jansenrw's Avatar
Default Re: 94.9% duty on injectors too high??? and how to fix!! (Big Phat R)
ok so what will the fpr do for the car????
If this is true what you are saying then I'll just get them flowed!
Old May 21, 2003 | 05:44 PM
Big Phat R's Avatar
Think of a garden hose with a sprayer on the end. Imagine the sprayer has a very small hole in it. Now increase the pressure in the hose - what happens? Do you get a <u>lot more</u> water coming through the hose?? NO - but the spray will be a lot finer due to the increased pressure and you also end up stressing the hose.
Injectors run at too high duty cycle can fail - which means motor go boom!
Bigger injectors are like increasing the size of the hole at the sprayer end. A fuel pressure regulator/riser increases the pressure of the fuel.
when you increase the flow rate of the injectors you can overwhelm the ability of the stock fuel pump to keep up with the extra fuel demands. On cars that have really high fuel needs - a bigger fuel pump is also recommended.
Old May 21, 2003 | 05:46 PM
jansenrw's Avatar
awesome.. nice to know that i have enlightenment for today!!!
Jan 31, 2010 02:46 PM
Djbower1
Dec 27, 2005 02:56 AM
tnsxsear1
Sep 11, 2004 09:01 PM
7rrivera7
Aug 21, 2003 10:07 AM
Malice
Jun 7, 2002 11:31 AM
