Do-Luck room bar
Old May 21, 2003 | 03:32 PM
whtdc2's Avatar
New User
Default Do-Luck room bar
I've just bought a set of the above room bar, just want to know how you guys fit it?? Do I have to cut the carpet? Thanks
Old May 21, 2003 | 03:43 PM
Big Phat R's Avatar
Default Re: Do-Luck room bar (whtdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whtdc2 &raquo;</TD></TR><TR><TD CLASS="quote">I've just bought a set of the above room bar, just want to know how you guys fit it?? Do I have to cut the carpet? Thanks</TD></TR></TABLE>
Old May 21, 2003 | 03:48 PM
RagingAngel's Avatar
Default Re: Do-Luck room bar (Big Phat R)
HAHAHhahaa...
nice bunny...
yes it is necessary to cut the carpet and ensure you tension it properly or it's pretty much useless....
Old May 21, 2003 | 03:59 PM
uNF$@#!'s Avatar
Old May 21, 2003 | 04:15 PM
whtdc2's Avatar
New User
Default Re: Do-Luck room bar (Soup ****)
thanks Soup **** , if possible can you post a pictue to show how you cut the carpet, thanks.
Old May 21, 2003 | 04:28 PM
WiggiE's Avatar
New User
Do those things make a difference??
Old May 21, 2003 | 04:38 PM
sublimnal's Avatar
Default Re: Do-Luck room bar (WiggiE)
i am wondering if they do anything improvement too. becuase aerospeed sells it and their products are
Old May 21, 2003 | 04:39 PM
Dr Pooface's Avatar
Default Re: Do-Luck room bar (vtec-holic)
Where does it bolt to?
Old May 21, 2003 | 04:51 PM
RaVAGE00's Avatar
New User
Default Re: Do-Luck room bar (Dr Pooface)
I have the Du-lock.... it makes a difference....
As for the installation, I will give you a tip that no one mentioned to me..... in order to get the bar to fit, you need to remove the large nut that sits in the middle of the bars at the threaded connection piont.
It bolts on the seat belt securing bolts. You do not need to cut the carpet.... You will need to use alot a force to get the bar into bolting position... its a TIGHT fit.
Hope this helps.
Old May 21, 2003 | 05:25 PM
WiggiE's Avatar
New User
Default Re: Do-Luck room bar (RaVAGE00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaVAGE00 &raquo;</TD></TR><TR><TD CLASS="quote">I have the Du-lock.... it makes a difference.... </TD></TR></TABLE>
What kind of difference?
Also, is it worth the money you paid for it?
Old May 21, 2003 | 06:07 PM
RaVAGE00's Avatar
New User
It is makes a difference enough to feel. The car seems more stable in the corners... and yes it was worth it... since I was able to secure a very good deal.
Old May 21, 2003 | 06:09 PM
B2FiNiTY's Avatar
How much do they usually cost?
Old May 21, 2003 | 06:10 PM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaVAGE00 &raquo;</TD></TR><TR><TD CLASS="quote">It is makes a difference enough to feel. </TD></TR></TABLE>
wtf? got ritalin?
Old May 21, 2003 | 08:39 PM
Daryl_SP's Avatar
If anyone is interested in the Do-Luck floor brace or any of their products, feel free to contact me. We are a Do-Luck distributor.
Old May 22, 2003 | 12:06 AM
FJO3's Avatar
Default Re: Do-Luck room bar (Daryl_SP)
I'm with dr pooface, where does it bolt to? Never seen this before and wondering if it actually does anything...
Old May 22, 2003 | 01:03 AM
sublimnal's Avatar
Default Re: Do-Luck room bar (2000R#1355)
so how much does this do luck bar cost that you say is works. aerospeed makes one and it coss like 90 bucks. i don't think it does anything. you already have a frame piece in the middle of your car why you need another one.
Old May 22, 2003 | 02:51 AM
Maximus's Avatar
http://www.do-luck-usa.com/assistbars.html
They cost $350 retail but who wants to pay retail? IM me
Old May 22, 2003 | 04:39 AM
vactor's Avatar
Default Re: Do-Luck room bar (Maximus)
the Do-Luck bar i got for my Honda Civic was INCREDIBLE! by far the best chassis stiffening device i came across. the feel of teh car was dramatically different in that it was much easier to control at the limit and felt much mor responseve. i can also jack up 1 corner of the car and open/close the door which was previously not possible on my car, so i know the chassis has become significantly stiffer. i give the Do-Luck a HUUUGE ....
Old May 22, 2003 | 05:25 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Do-Luck room bar (vactor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vactor &raquo;</TD></TR><TR><TD CLASS="quote">i can also jack up 1 corner of the car and open/close the door which was previously not possible on my car</TD></TR></TABLE>
I can do that on my Volvo station wagon. And can lift three tires off the ground from one jacking point.
I have a hard time seeing how that floor bar helps reduce chassis twist, unless it is VERY strong.
Old May 22, 2003 | 05:49 AM
RaVAGE00's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">
wtf? got ritalin?</TD></TR></TABLE>
Sorry???? I was asked if the brace made a difference.... so, I responded that, yes, in fact it did make a difference... enough so that I could feel the car seemed to be more neutral going into corners....
I don’t take Ritalin, I prefer Prozac!
Old May 22, 2003 | 05:50 AM
RaVAGE00's Avatar
New User
Default Re: Do-Luck room bar (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">
I have a hard time seeing how that floor bar helps reduce chassis twist, unless it is VERY strong.</TD></TR></TABLE>
The bar is very, very strong....
Old May 22, 2003 | 05:53 AM
RaVAGE00's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000R#1355 &raquo;</TD></TR><TR><TD CLASS="quote">I'm with dr pooface, where does it bolt to? Never seen this before and wondering if it actually does anything...</TD></TR></TABLE>
As mentioned, the brace connects directly to the seatbelt fastening bolts on either side of the car…. These bolts connect directly into the vehicles chassis.
Old May 22, 2003 | 10:58 AM
slofu's Avatar
will this thing fit a del sol?
Old May 22, 2003 | 11:02 AM
RaVAGE00's Avatar
New User
Default Re: Do-Luck room bar (slofu)
not sure. they have different bars for different cars.
Old May 22, 2003 | 02:30 PM
Project X's Avatar
Nah, this bar doesn't do anything just like the front/rear strut tower bars, tie bars, sway bars, etc. I have no idea why the Type R came with those.
