Is it possible to run a D series motor w/ JDM ITR 5 lug
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1 '96 Coupe »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=512366
This guy did it. So I am asuming it will work</TD></TR></TABLE>
nowhere in that post did he mention it was a JDM ITR 5 lug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">yes, why not?</TD></TR></TABLE>
D series axles are 32mm JDM ITR axles are 36mm.
I've been driving a completely stock '97 Civic EX (w/ SOHC VTEC) for 6 years, 40,000 miles and have been constantly getting around 35 mpg doing mostly freeway driving. I recently got the following parts installed and since then, I started getting around 28 mpg doing the same kind of driving:
ITR 5 lug conversion
15" ITR wheels w/ 195/55/15 Bridgestone Potenza RE010 tires
Mugen Sports Suspension System
Ok ITR not JDM
Ok ITR not JDM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">USDM ITR and JDM ITR 5 lug is different.</TD></TR></TABLE>
yes but it depends what year, the bigger axles were only on the later model ones. i want to say after 98
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious »</TD></TR><TR><TD CLASS="quote">
yes but it depends what year, the bigger axles were only on the later model ones. i want to say after 98</TD></TR></TABLE>
yeah, but anything before 98 was 4 lug!
so if i get the JDM axles with the 32mm inner and the 36 mm outter then i can use it on my stock motor for now until i get my motor right ? y0 you mentioned that the d series motors are 32mm. My car is a 97
yeah, but anything before 98 was 4 lug!</TD></TR></TABLE> your absolutely wrong
pre 97 was 4 lug
pre 97 was 4 lug
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious »</TD></TR><TR><TD CLASS="quote"> your absolutely wrong
pre 97 was 4 lug</TD></TR></TABLE>
ah, my bad. i know something changed in 98 though
96-7 JDM ITR = 4x114, GSR sized brakes, 'standard' 32mm axles
98-01 JDM ITR = 5 bolt, USDM ITR sized brakes, 36mm axles
97-01 USDM ITR and 97-00 JDM CTR = 5 bolt, 32mm axles
to use the the 98+ JDM ITR front brakes you need 36mm out axles (so the only option is to swap out the outer joints for the CRV or Accord or Prelude) or run a OBDI DOHC/SOHC ZC type hydro tranny from a JDM teg which requires and uses b-series axles and intermideate shaft, therfore then the only obsticale would be to get those 98+ ITR axles (36mm axles).
SPOONfdEK
15
Apr 1, 2005 03:39 AM
jp8900
Nov 12, 2003 10:27 AM
