knock sensor on first gen b16
Old May 21, 2003 | 02:40 PM
JDMCivicHatch93's Avatar
Default knock sensor on first gen b16
i have a first get b16 and pr3 ecu. its thoughing a code 23, knock sensor. i have searched for a good picture but i didnt find one. if anyone has a good pic of where it is so i can find mine. i know its under the intake man. but theres a couple of things back there that look like they could be it i just dont know which one.
Old May 21, 2003 | 04:03 PM
FitCRX's Avatar
Default Re: knock sensor on first gen b16 (JDMCivicHatch93)
there are 3 things down there(as I remeber)
1)temp switch...two round connections
2)oil pressure signal....one round connections
3)knock.....one flat connection
the connections Im talking bout are with the sensors unpluged
Old May 21, 2003 | 07:29 PM
Default Re: knock sensor on first gen b16 (FitCRX)
ok cool thanks dawg, that helps. but you dont happen to have a pic or digram do ya??
Old May 21, 2003 | 08:04 PM
Russ713's Avatar
dAng!
the knock sensor is on the back side of the short block facing the firewall.
If you were to reach under the intake manifold, the sensor would be located 'just' under the head gasket and towards the middle of the block. It only has one wire plugged into the sensor.
EFjoe91
Mar 5, 2016 06:17 AM
blasterman87
Jun 6, 2010 07:04 AM
davidu
10
Jul 27, 2008 11:01 AM
DC2tuner
Jan 5, 2005 03:58 PM
W0oT
10
Aug 18, 2002 01:18 PM
