B18C1 in a CRX? opinions...
Old May 21, 2003 | 02:34 PM
LoooseGSR's Avatar
Default B18C1 in a CRX? opinions...
I was thinking that since everyone is doing the B16(which is still an option) I was thinking about putting in a B18C1 in my CRX and using a YS1 tranny out of the 92-93 Integra GSR. Also, I was wondering if it might be possible to turbo charge a CRX and STILL be able to keep A/C. I just graduated from college so money hopefully won't be that big of a deal in about 5-6 months(I plan on doing the swap this winter).
Old May 21, 2003 | 02:43 PM
KooK's Avatar
Mustang Sally
Default Re: B18C1 in a CRX? opinions... (PSUCRX)
If you have the money it should be no real problem. Sure you can keep the AC with a turbo. I want a B18c1 in my CRX but thats alot of extra money for me just for the extra 200cc over the B16A. Of course it'll always be able to go faster and have better torque.
Don't do it to stand out though, if you want to stand out then swap it with an AWD system. Do it because you love the power.
Old May 21, 2003 | 02:57 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PSUCRX &raquo;</TD></TR><TR><TD CLASS="quote">I just graduated from college so money hopefully won't be that big of a deal in about 5-6 months(I plan on doing the swap this winter).</TD></TR></TABLE>
if you can find a deal on everything go for it...otherwise save some of your money. i graduated with a BS last may and i havent even been able to get an interview, let alone a job. ive got a BS in mechanical engineering tech with a minor in mathematics and i am a part time janitor. thats why i stuck with the d-series stuff. good thing i paid for college already...never took out a loan.
that would be about the best tranny though, does that have the optional LSD or is that just the JDM ys1?
Old May 21, 2003 | 04:27 PM
incubus's Avatar
Default Re: B18C1 in a CRX? opinions... (fastcrxsi90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrxsi90 &raquo;</TD></TR><TR><TD CLASS="quote">
that would be about the best tranny though, does that have the optional LSD or is that just the JDM ys1?</TD></TR></TABLE>
He is talking about the usdm GSR YS1 tranny (no LSD).
It might be hard for you to source that tranny by itself, however you wouldnt have to deal with the trouble of a cable to hydro tranny conversion that way.
Old May 21, 2003 | 05:03 PM
Default Re: B18C1 in a CRX? opinions... (incubus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incubus &raquo;</TD></TR><TR><TD CLASS="quote">
yeah i know he meant usdm ys1...for some reason i was thinking that it had as optional LSD too.
heres your tranny...... https://honda-tech.com/zerothread?id=512483
i dont know who this guy is...i just saw it when checking the classifieds.
Old May 21, 2003 | 05:50 PM
Fobtions's Avatar
the cheapest thing to do is to get a b16a complete swap first, then buy a b18c. Because if you go and buy a b18c swap all you can use out of it is the block and head. you can use the electronics, but have to get a jumper harness
Its alot harder to change over to a b18c if you are going from D-series to b18c.
Old May 21, 2003 | 06:06 PM
ninjaMONKEY
Guest
Posts: n/a
Default Re: B18C1 in a CRX? opinions... (Fobtions)
FOOD FOR THOUGHT
Id say get a b20 long block to use with the tranny. Trade your tranny and some cash for one with lsd if it doesn't already have it. Money isnt an issue regardless... the b20 long block is normaly $1,000.00+ cheeper then a b18c long block. And is much better for turbo lots of torque to get you through boost lag city.
All motor get the b18c
Old May 21, 2003 | 06:46 PM
LoooseGSR's Avatar
Default Re: B18C1 in a CRX? opinions... (coleco)
I keep hearing B20 with GSR head...but the only problem with this is I hear there are drivability issues going with an LS/CRVTEC setup...this is going to be my daily driver.
Old May 21, 2003 | 07:33 PM
redlineb18's Avatar
might have to get half radiator if you wanna go turbo. the smallest exhaust manifold i believe is the log style, prolly least efficient for power but hey, it works. i put a b18a1 in my 89 civic sedan lx which is quite similar to your car, although i didn't keep the A.C.
Old May 21, 2003 | 10:10 PM
J Money's Avatar
Default Re: B18C1 in a CRX? opinions... (redlineb18)
Another good alternative would be to use a B18c bottom end with a b16a head. That way you retain the oil squirters and also have a bottom end that is meant for high rpm. The B16a head is a better head than the B18c and much cheaper. FWIW, A boosted B16a alone will be fast enough if it is done right, especially in a crx.
Old May 21, 2003 | 10:41 PM
civisaurusrex's Avatar
Default Re: B18C1 in a CRX? opinions... (J Money)
how about a b20, no vtec, and a turbo. the turbo will be happier without the vtec swith anyways.
Old May 21, 2003 | 10:43 PM
gray89si's Avatar
I think the USDM YS1 is a good choice, it runs at a lower rpm in 5th gear than its JDM counterpart does(a really nice feature if youve ever driven a JDM B16A for an extended time). However, finding it will be the challenge, the 92-93 GSR isnt a very common car to begin with, so there arent a whole lot of parts for them floating around in salvage yards. If you can find one in good shape, itd definitely be worth getting. Also, the B17 motor that the 92-93 GSR came equipped with has more torque than the B16A did, but is otherwise a B16A, only bored out a little more at the factory.
Old May 22, 2003 | 12:34 AM
1st-hybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">
Its alot harder to change over to a b18c if you are going from D-series to b18c.</TD></TR></TABLE>
Holy miss information batman .
It is no harder to swap in a b18c than it is a b16. Yes you have to convert to obd1, but that is easy. You actually don't even need to convert, you can getthe zdyne and stay obd0 if you want.
Old May 22, 2003 | 04:52 AM
WuShu's Avatar
New User
Default Re: B18C1 in a CRX? opinions... (1st-hybrid)
Retaining AC is easy, just depends on the manifold and downpipe you get.
eREXion91
Oct 24, 2010 09:32 AM
caragan11
Oct 13, 2009 02:29 PM
pepin15
Jul 21, 2004 11:50 AM
Big Bang
Oct 14, 2003 06:28 AM
