GC coilovers 5th gen vs. 4th
Old May 21, 2003 | 06:41 AM
munscher's Avatar
Default GC coilovers 5th gen vs. 4th
ANybody know if there's a difference between 5th gen GC coilovers and 4th gen GC coilovers? I know that the 4th gen suspension setup has a bracket or a clamp or somesuch that holds a brakeline in place that the 5th gen does not have, but this is on the shock housing i believe? Is there any reason a 5th gen setup would not work on a 4th gen?
Also, does anyone know the stock spring rates on a standard (non custom spring rates) 5th gen GC coilover setup?
Old May 21, 2003 | 07:44 AM
Elkins911's Avatar
Default Re: GC coilovers 5th gen vs. 4th (munscher)
i think the spring rate is the only difference. dont think thats written in stone. a generic coil over is a generic coil oil. throw down the money for a true tein coil over. thats what im doing.
Old May 21, 2003 | 08:54 AM
munscher's Avatar
Default Re: GC coilovers 5th gen vs. 4th (Elkins911)
Well, i plan on TEIN FLEX w/ the electronic control, just not anytime soon b/c $1300 for a suspension setup is just plain more than i can afford right this second. But on the other hand i'm tired of seeing my car sit so high so something has to be done about it short term (for a year or two). I'd prefer not to put sprint lowering springs or some other cheap option, so i'm looking at other alternatives for the time being, probably used.
Old May 21, 2003 | 09:13 AM
ophdehEEzY
Guest
Posts: n/a
im using 5th gen coilovers in my 4th gen.
Old May 21, 2003 | 02:30 PM
Merritt_si's Avatar
Default Re: GC coilovers 5th gen vs. 4th (ophdeheezy)
Check out my setup. Wasn't overly expensive and I didn't need a camber kit. Handles SO MUCH BETTER and it is even smoother than when it was stock. Good luck playa.
Peace
Old May 21, 2003 | 04:15 PM
Elkins911's Avatar
Default Re: GC coilovers 5th gen vs. 4th (Merritt_si)
GC coilovers arnt a cheap option. how much they run you? 300???? 400????
thats almost half of what you need for the tein! if your going to get the teins in a year, why spend the money on the GC coilovers?!?! spend that money on something else.... or save it and get the true coilover system. does this make sense to anyone else?
Old May 21, 2003 | 05:35 PM
illusion's Avatar
the GC is a $300 setup and when paired with koni shocks i would imagine would perform just as well as a low end tein setup which you are referring to. plus with GC/koni, you can easily upgrade spring rates and have the shocks serviced. tein's us headquarters have been known for a long turnaround time.
either way you will have a very nice suspension.
AsiAnVenOm
Jul 30, 2006 08:48 AM
darockstar
Apr 2, 2006 07:52 PM
chaudanova
May 28, 2003 05:35 AM
PearlWhiteAccord
Jul 20, 2002 03:05 AM
Fly1865
Jul 16, 2002 11:01 AM
