fuse keeps blowing
Old May 21, 2003 | 12:18 AM
neoburi's Avatar
Default fuse keeps blowing
i have 88 dx, and i have blown 5 gauge / tail lights fuse in this week..
i know i may have a short somewhere,
but how can i check that ****?
the wire or plug has to be related with the gauge and tail lights?
and, is the fuse 25 amp? i lost fuse panel..
somebody please help me out!!!
did search a lot.. no flame please..
Old May 21, 2003 | 02:12 AM
civisaurusrex's Avatar
Default Re: fuse keeps blowing (neoburi)
get a 12 volt test light and a wiring diagram. connect one end of the test light to the positive terminal of the battery. use the other end to probe all of the connectors on that circuit. if you've had any body work done or re-installed any interior panels recently start in that area to see if there's a pinched wire. otherwise, start at the tail lights and work your way up to the fuse panel. then try the dash connectors. if the test light comes on dim, and your dash lights come on too, then there's no short on that wire. if it lights at full brightness, then you've found the wire with the short.
Old May 21, 2003 | 07:19 AM
brent_G's Avatar
Default Re: fuse keeps blowing (civisaurusrex)
i had that problem with my crx about 3 weeks ago. IT ended up being a wire behind the guage cluster that was being pinched between the metal frame and the dash board...it was a rather large part of the harness that was behind the cluster. pretty easy to see...check that and make sure it didnt wear a spot in on of the wires. It was small and stupid and really pissed me off. And i spent about 15 hours looking for what was wrong and thats what it was. Also check the grounds in the back on the tail lights.
Old May 21, 2003 | 06:46 PM
neoburi's Avatar
thanks,
anyway, can sombody confirm the fuse 25amp or 15amp?
Old May 21, 2003 | 06:58 PM
brent_G's Avatar
Default Re: (neoburi)
the running lights fuse for the dash lights and the running lights is a 10amp fuse...
Old May 21, 2003 | 07:33 PM
neoburi's Avatar
confused... -_-
so, the fuse for the gauge light, tail light is 10?
does somebody have a pic? would be great..
Old May 21, 2003 | 08:32 PM
sitrucjr's Avatar
i had that same problem when i bought my car,,the fuse was located under the hood i think it s a 10 fuse,,the horn and the taillights share the same fuse,,,i located my horn wich is located infront of the driver side front wheel and it turned out that the horn was disconected and shorting on the frame of the car
Old May 21, 2003 | 09:43 PM
neoburi's Avatar
thanks guys,, really appreciate those reples..
the fuse is 10 amp, just downloaded manual and checked the diagram..
damn.. i bought this car about a month ago, and the previous owner put a 25amp there..
that's why i was so confused about that..
i will check the all wires and connections hopely in this weekend..
and i will check all the fuses.. sucker...
Old May 21, 2003 | 09:56 PM
brent_G's Avatar
adding larger amp fuses is no good...thats the reasons fires start...instead of the fuse blowing it will cuase heat in whatever is caussing the fuse to blow and could eventually start a fire if the conditions are right...so make sure you use the 10!
Old May 21, 2003 | 11:25 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: (screamincivik)
just hack into the red/black wire and wire a switch in. that's what my lazy *** did after a year of no taillights and 2 tickets.
Old May 24, 2003 | 10:57 AM
neoburi's Avatar
WTF is going on!!!
i checked the fuses right now and found so many wrong amp fuses were there if i am right..
please confirm the fuse!!!
# (in fuse box) ----- (according to manual)
#1 (20 amp) (10 amp)
#2 (10 amp) (?)
#3 (10 amp) (20 amp)
#4 (10 amp) (10 amp)
#5 (10 amp) (10 amp)
#6 (20 amp) (30 amp)
#7 (30 amp) (10 amp)
#8 this is the dash lights / tail lights
#9 (20 amp) (10 amp)
#10 (20 amp) (10 amp)
#11 (20 amp) (10 amp)
#12 (10 amp) (15 amp)
#13 (15 amp) (15 amp)
#14 (10 amp) (10 amp)
#15 (15 amp) (15 amp)
#16 (15 amp) (10 amp)
#17 (10 amp) (10 amp)
#18 (10 amp) (10 amp)
I need help ASAP!!!!
fuse panel pic would be greatly appreciated!!
again, 88 dx b16a
Old May 24, 2003 | 11:03 AM
neoburi's Avatar
Goddamn...
i just found that i am looking at crx manual...
i maybe wrong about the fuse amp...
anyway, please help me!!!
Old May 24, 2003 | 10:15 PM
neoburi's Avatar
it seems nobody has a fuse panel.. -_-
please somebody help me!!
Old May 24, 2003 | 10:44 PM
brent_G's Avatar
I have a fuse panel...just no camera
tsdork
Feb 18, 2016 12:46 PM
blackakkord
Jan 31, 2008 05:46 PM
turbo sol
Aug 25, 2003 08:49 AM
S13 slide
Jan 20, 2002 10:35 PM
FUP23
11
Nov 2, 2001 03:35 AM
