help on d16z6 timing belt
alot.... make sure the piston is tdc if you aren't sure take out the #1 spark plug and put it in there.... you can tell when it goes all the way up that is tdc if your having trouble.... also for the tensioner use a pry bar and pry it... makes life alot easier.... and you will also need the crank pully tool unless u got an air gun hope this helps
honda4fun
Jun 11, 2009 10:11 AM
hmtcrxsir
Nov 1, 2005 03:07 AM
