JDM ITR 5 lug conversion, what axles 36mm...
Old May 20, 2003 | 09:51 PM
SPOONfdEK's Avatar
Default JDM ITR 5 lug conversion, what axles 36mm...
when doing a JDM ITR 5 lug conversion on a EK, what axles are used the 36mm or 32mm ones. I've always been under the impression that you use the OEM ones(32mm) that the car originally had until you do a motor swap. Now i read that the jdm ITR axles are 36mm on the outer and 32 mm on the inner, TIA
Old May 20, 2003 | 09:52 PM
Chris y0!'s Avatar
Default Re: JDM ITR 5 lug conversion, what axles 36mm... (SPOONfdEK)
you use 36 mm axles y0!
Old May 20, 2003 | 09:53 PM
function83's Avatar
Default Re: JDM ITR 5 lug conversion, what axles 36mm... (Chris y0!)
yes jdm itr 5 lug uses 36mm axles........as stated above^
unless you wanna get ctr 5 lug then it is still 32mm.
or us spec. itr 5 lug.
Old May 20, 2003 | 09:57 PM
SPOONfdEK's Avatar
Default Re: JDM ITR 5 lug conversion, what axles 36mm... (djhatch)
then how do you get them to fit on the side of the motor
Old May 20, 2003 | 10:02 PM
Chris y0!'s Avatar
do you have a D series?
Old May 20, 2003 | 10:05 PM
SPOONfdEK's Avatar
i have a cx in the car right now but i wanted to start by doing the suspension and brakes, how can i do this without swapping the motor yet
Old May 20, 2003 | 10:16 PM
Chris y0!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOONfdEK &raquo;</TD></TR><TR><TD CLASS="quote">i have a cx in the car right now but i wanted to start by doing the suspension and brakes, how can i do this without swapping the motor yet</TD></TR></TABLE>
i don't think you can. but then again i don't know anything.
CTR and USDM ITR 5 lug conversions will work with the stock axles, however.
Old May 20, 2003 | 10:21 PM
SPOONfdEK's Avatar
what size axles do the B series motors use 36 or 32 mm ? there is a guy that is telling me that he is using 36 on the outside and 32 on the motor side , how the hell ???
Old May 20, 2003 | 10:23 PM
Chris y0!'s Avatar
dude, i think all honda axles are 32 on the engine side, only the JDM ITR is 36 on the hub side.
Old May 20, 2003 | 10:28 PM
tonyxcom's Avatar
I know some people put prelude outsides on their b series axles, dont think you can do that with d series axles.
Your other option is to buy some 32mm hubs from the dealer and have them pressed in. Not sure the inner bearing race is the same size though. Since you will probably separate (ruin) the bearings taking the hub out, you could always get some US bearings too, but I am not sure the outer diameter is the same.
Old Mar 30, 2005 | 11:03 PM
marko_think's Avatar
Default Re: JDM ITR 5 lug conversion, what axles 36mm... (tonyXcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom &raquo;</TD></TR><TR><TD CLASS="quote">I know some people put prelude outsides on their b series axles, dont think you can do that with d series axles.
Your other option is to buy some 32mm hubs from the dealer and have them pressed in. Not sure the inner bearing race is the same size though. Since you will probably separate (ruin) the bearings taking the hub out, you could always get some US bearings too, but I am not sure the outer diameter is the same.</TD></TR></TABLE>
is there a write up on that?
Old Mar 31, 2005 | 12:13 AM
GZR4DR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOONfdEK &raquo;</TD></TR><TR><TD CLASS="quote">what size axles do the B series motors use 36 or 32 mm ? there is a guy that is telling me that he is using 36 on the outside and 32 on the motor side , how the hell ???</TD></TR></TABLE>
The axle is 3 pieces, 2 hubs and 1 shaft. All he did was replace a hub, the sizes on the outside did not matter. USDM B series motors use 32mm axles, JDM ITR use 36mm. Either get some JDM ITR axle hubs (or axles) or replace the outer hubs on your current axles. Go to an axle shop and they'll get you squared away. Make sure you get ones with the ABS ring if your car has ABS. This is a lot easier than it sounds, just go to an axle shop.
Old Mar 31, 2005 | 02:34 AM
137's Avatar
137
Default Re: JDM ITR 5 lug conversion, what axles 36mm... (GZR4DR)
EKcoupe99 has an ex with a 5 lug conversion. Hit him up about it.
Old Mar 31, 2005 | 06:28 AM
CivicESi's Avatar
Default Re: JDM ITR 5 lug conversion, what axles 36mm... (137)
JDM ITR was 5lug/36mm from 98&gt;, they were 4 lug before 98 All others B series, EK9, EDM and USDM 5 lug are all 32mm. If you have 36mm hubs, you just need JDM ITR outer joints, though heard rumours the CRV had 36mm outer joints that fit. If you have 32mm 5 lug hubs any b series axle will work, i know as i have 32mm outer joints on JDM ITR shafts in an B18C EG
If ya need the joints, i have a mint set, shipping will cost ya bit since i am in the UK, but will fix the problem
Old Mar 31, 2005 | 10:01 AM
Default Re: JDM ITR 5 lug conversion, what axles 36mm... (slow poke)
will the 97+prelude axles work fine into a gsr tranny (no swaping outter joints) with a jdm 5 lug convo?
Old Apr 1, 2005 | 03:39 AM
CivicESi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke &raquo;</TD></TR><TR><TD CLASS="quote">
Very close but not quite. ONLY 98 JDM ITR's came with 36mm axles. 99-01 came with 32mm units. Everything else is right
Since i have a 00 JDM ITR motor and shafts in mine, and can guarantee that it came with 36mm joints/hubs, it was not only 98 JDM ITRs that came with it
Make sure your info is good as i know mine is, as the motor came out of a JDM ITR-X which was only 00-01, i saw the car so i know for sure, i aldo know others with JDM ITR's, all are 36mm AFAIK
To repeat ALL 98-01 JDM ITR's are 36mm axles
All of the other info may be good, like i said, heard somat about CRV outers bolting onto SOHC shafts, not sure about the details though
jxnguyen
Apr 21, 2015 05:57 PM
Ek9_Cuhzz
Northwest (Sales)
Jul 27, 2010 09:08 PM
Boriqua0555
Jun 28, 2007 10:13 AM
cashkid2004
Oct 1, 2006 06:41 AM
h22teg
Mar 28, 2005 07:09 AM
