Buy or make race gas???
Old May 20, 2003 | 09:34 PM
J2turbo21's Avatar
Default Buy or make race gas???
I was wondering if you guys buy or make your own race gas?I found this link that tells you how to make it and what is needed.
http://www.gnttype.org/techare....html
I was thinking about mixing up a batch of this.If i add 3.3gallons of Xylene to my gas tank and fill the rest up with 92octane i should get an octane rating of 99.5.
FORMULA 2
Xylene
R+M/2...117
Cost...$2.75/gal
Mixtures with 92 Octane Premium
10%...94.5 Octane
20%...97.0 Octane
30%...99.5 Octane
Notes: Similar to Toulene. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Usually mixed with Toulene and advertised as *race formula*.
Old May 20, 2003 | 10:07 PM
Elex's Avatar
Default Re: Buy or make race gas??? (J2turbo21)
just buy a drum of VP
Old May 21, 2003 | 08:56 AM
martini's Avatar
if you make your own gas, it won't be NHRA legal..
in case you're going to be racing NHRA that is..
Old May 23, 2003 | 06:22 PM
J2turbo21's Avatar
Default Re: Buy or make race gas??? (martini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martini &raquo;</TD></TR><TR><TD CLASS="quote">if you make your own gas, it won't be NHRA legal..
in case you're going to be racing NHRA that is..</TD></TR></TABLE>
I didnt know that,but naw im not racing in the NHRA its just to get around town and to the tracks is all.
Old May 24, 2003 | 05:05 AM
google's Avatar
that is so cheap and ghetto but for thinking about that one.
Old May 24, 2003 | 07:40 AM
Suprdave's Avatar
One thing about the Toulene, is has to be warm to be effective.
So living in alaska, you might have some issues. Formula 1 teams used to run 76%? Toulene as a fuel, with like the rest an inert gas....so basically 100%. Anyways, they ran heaters on the gas tanks that directed exhaust heat over the tank. Just FYI
Suprdave
Old May 24, 2003 | 04:21 PM
J2turbo21's Avatar
Default Re: Buy or make race gas??? (Suprdave)
Thanks Suprdave for that info.Do you know anything else about the other chemicals that were listed,like Xylene?
Old May 24, 2003 | 09:54 PM
Rob Dizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">One thing about the Toulene, is has to be warm to be effective.
Suprdave</TD></TR></TABLE>
thats interesting chemisty happening there. remember the normal thinking with gas, is that you want it to be as cold as possible. To bad in dont have a degree in chemistry to explain why toulene needs to be warm to have good burn properties
Old May 25, 2003 | 03:45 AM
J2turbo21's Avatar
Default Re: Buy or make race gas??? (Bob-DC2)
Here is some more info i found about making some race gas.It does mention what SuprDave says about F1 cars using it.
I still think i will give it a try,but i'll keep it in a war area and add it when i go to the track.
http://www.gnttype.org/techarea/misc/miscpage.html
Old May 25, 2003 | 02:21 PM
intekragsr's Avatar
hmmm im may look into this. toulene is kind of expensive though.
Old May 25, 2003 | 03:51 PM
J2turbo21's Avatar
Default Re: Buy or make race gas??? (intekragsr)
Its about $2.50 a gallon and i figured 3.5 gallons mixed with 7.5gallon pump gas in a civic makes 100oct rating.
Old May 25, 2003 | 08:12 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">hmmm im may look into this. toulene is kind of expensive though. </TD></TR></TABLE>
For most people, it's not as expensive as buying some 104, and MUCH more readily available. I have lots of GN buddies that use this, I was thinking of doing the same thing, but i'll just stick to alky/water or propane injection and have it always be there
Old May 25, 2003 | 08:17 PM
intekragsr's Avatar
Default Re: Buy or make race gas??? (boosted92)
sorry for the noob question, but what is alky/water injection?
Old May 26, 2003 | 09:53 PM
MugenGTR's Avatar
i agree, jus BUY race gas and mix it w/ pump gas to lower the octane a bit,
Old May 26, 2003 | 09:57 PM
MugenGTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">Anyways, they ran heaters on the gas tanks that directed exhaust heat over the tank.
i would also like to highly discourage anyone to try to ghetto rig this setup
Old May 26, 2003 | 09:59 PM
J2turbo21's Avatar
Default Re: Buy or make race gas??? (MugenGTR)
If i mix 116 with pump gas,a half and half mix will get you 104oct.It just seems a little cheaper to add some toulene.I'll just store it in a warm place.
Old May 27, 2003 | 01:15 AM
Elex's Avatar
VP MS-103
Old May 27, 2003 | 01:24 AM
J2turbo21's Avatar
Default Re: Buy or make race gas??? (BSeriesMadness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSeriesMadness &raquo;</TD></TR><TR><TD CLASS="quote">VP MS-103</TD></TR></TABLE>
Is that a kind of race gas?
Old May 27, 2003 | 01:45 AM
Elex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">
Is that a kind of race gas?</TD></TR></TABLE>
VP's unleaded race gas. 100 octane comes in 55 gallon drums
76/Unocal sells 100 on the pump also in certain places.
Old Dec 28, 2003 | 04:10 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Buy or make race gas??? (Elex)
back from the dead......
toluene vs. Xylene
114 vs. 117
any other differences? is Xylene any less heat sensitive? can you run either straight... or rather, can you have too much of either in your "mix"?
-Erik
Old Dec 29, 2003 | 05:38 PM
xsiv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenGTR &raquo;</TD></TR><TR><TD CLASS="quote">i agree, jus BUY race gas and mix it w/ pump gas to lower the octane a bit,</TD></TR></TABLE>Do you necessarily have to mix the two types of gas in a seperate container (shaking it) then pour it in your tank? -- To get a good mix.
Or can you just pump the 100 octane then drive to a gas station and pump in the 91 octane?--Will it ping since the two gases aren't evenly mixed?
WHat do ya'll do?
Old Dec 30, 2003 | 05:12 PM
FRISKY's Avatar
Link to VP Race Fuel site: http://www.vpracingfuels.com/i...7C264
Old Dec 30, 2003 | 06:02 PM
DIRep972's Avatar
Smarter than you
This doesn't help much but my supra buddies run "rice" gas(as they call it), a mix of toulene/93, all the time around here. They daily drive on it and it allows them to push 22-23psi of boost + more timing and adds about 50hp to their BPU turbo set ups..
I have never run it but I have considered running it daily in my car. My main concerns is the consistancy of it. How sure can you be that you get the right mix and a quality mix every time? The price is not really an issue. Generally mixing it 30% adds about 75cents onto the price of each gallon. Meaning id be paying app. 2.25-2.50/gal. for my gas which is still alot cheaper then mixing 104 w/ 93 or running strait 100octane.
I am assuming a mix of toulene/93 would still be unleaded right?
Old Dec 30, 2003 | 06:09 PM
FRISKY's Avatar
Default Re: Buy or make race gas??? (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">I am assuming a mix of toulene/93 would still be unleaded right?</TD></TR></TABLE>Yes, toulene is one of the basic chemicals that make up unleaded gasoline.
Old Dec 30, 2003 | 06:11 PM
New User
Default Re: Buy or make race gas??? (FRISKY)
my feeling on the mixing..... i dunno.... if i was going to the track i'ld buy race gas. for daily driving i'm going to mix. i'm generally not hard on my car daily driving so i'm sure it would have ample time to mix by the time it was stunna stompin time...
-Erik &lt;--- who's computer would take timing out if it started detonating anyway
TEGGRY
Mar 21, 2006 08:52 AM
B-A-N-A-N-A-S
May 20, 2005 11:52 PM
gsrapper
Sep 22, 2001 09:44 PM
