Supercharged ZC?
Old May 20, 2003 | 07:28 PM
Sherm's Avatar
Default Supercharged ZC?
I am planning on going turbo and my bro wants to buy my jrsc from me for his ZC crx. Has anyone on here done it and how does it all fit? We don't want to have to do any major modifications to fit it in there. Is there any cutting involved and does anything have to be relocated? Thanks
Old May 20, 2003 | 07:33 PM
matt j's Avatar
Default Re: Supercharged ZC? (Sherm)
it fits in there like it came from the factory that way, it will fit fine with no modification
Old May 20, 2003 | 07:49 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Supercharged ZC? (mattED6)
how many lbs of boost are you going to run?
Blaze
Old May 20, 2003 | 08:20 PM
Sherm's Avatar
Default Re: Supercharged ZC? (Blaze45)
6lbs to start with. I know he is going to want to upgrade in the future.
Old May 21, 2003 | 09:00 AM
redzcstandardhatch's Avatar
something different
if its for a single cam motor, and he has a dual cam zc, it will not fit, you'll need to call jackson, they make the manifold for the dual cam, you'd need to change that......if its for a single cam zc, it will work just fine. the manifold bolt pattern on the dual cam zc is different on the intake side, but not the exhaust side.
Old May 21, 2003 | 09:12 AM
sparq's Avatar
What pulleys does JR make for the ZC - like upto what, I imagine 9lbs? DOHC ZC would make what 200hp @ the crank?
Old May 21, 2003 | 09:20 AM
Brandon Chun's Avatar
Default Re: (sparq)
Someone else did this on another board, using a crv pulley if I recall correctly. He guestimated 200-215 crank hp.
charlieboyhonda
Jul 22, 2009 05:36 PM
HFpower
Mar 18, 2007 06:36 PM
marsbou
Sep 15, 2004 05:20 AM
Civicr2gs5
Oct 15, 2003 09:17 PM
