will 16x8 with +38 offset work on a ITR?
Old May 20, 2003 | 07:08 PM
DB8's Avatar
DB8
Default will 16x8 with +38 offset work on a ITR?
just wondering, friend got a set of these rims lying around, will these work without a problem of a ITR that's dropped little over 2inch on Tein HA? no cabmer kit.......
Old May 20, 2003 | 07:17 PM
Saga's Avatar
Default Re: will 16x8 with +38 offset work on a ITR? (DB8)
I am pretty sure that you will experience rubbing (even with the smallest tire possible on a 8" rim), not to mention the fact that ur car is dropped 2".
I know a few who have experienced rubbing with 7.5" rims, so I don't know how you can handle 8".
Old May 20, 2003 | 10:11 PM
ScaleExtric's Avatar
Default Re: will 16x8 with +38 offset work on a ITR? (Saga)
yah they'll work...just cant run a 215 size tire..stick with the 205/45 or lower..and you'll be fine
Old May 20, 2003 | 10:48 PM
Saga's Avatar
Default Re: will 16x8 with +38 offset work on a ITR? (ScaleExtric)
Hmm, please try not to pass on incorrect info because this can cause some serious safety issues.
FYI, You are not supposed to run 205s on 8", not even 7.5". By doing that, you are just asking for trouble.
Old May 20, 2003 | 10:54 PM
YellowKahuna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saga &raquo;</TD></TR><TR><TD CLASS="quote">Hmm, please try not to pass on incorrect info because this can cause some serious safety issues.
FYI, You are not supposed to run 205s on 8", not even 7.5". By doing that, you are just asking for trouble.</TD></TR></TABLE>
I do not recomend it either. I agree.
jdmjunky's Avatar
what kind of wheels are they?
Old May 21, 2003 | 12:22 AM
vtec.dc2's Avatar
what kind of safety issues? i plan to do similar with 15x7 and 195/55
Old May 21, 2003 | 12:51 AM
Saga's Avatar
Default Re: will 16x8 with +38 offset work on a ITR? (vtec.dc2)
There's a minimum acceptable rim width that a tire can take.
The idea is that each tire has a designed flex point in its sidewall. When you have a rim that is too wide, the resulting flex pt moves towards the rim. So now the lower part of the sidewall is much closer to the ground (it might even be in contact with the ground). This would cause the lower part of the sidewall to heatup(reduce tire life) or fail (damaged sidewall).
Old May 21, 2003 | 01:03 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saga &raquo;</TD></TR><TR><TD CLASS="quote">There's a minimum acceptable rim width that a tire can take.
The idea is that each tire has a designed flex point in its sidewall. When you have a rim that is too wide, the resulting flex pt moves towards the rim. So now the lower part of the sidewall is much closer to the ground (it might even be in contact with the ground). This would cause the lower part of the sidewall to heatup(reduce tire life) or fail (damaged sidewall).</TD></TR></TABLE>
i see, didn't think of it that way. thanks for explaining
ntensehonda
Honda S2000
30
Nov 7, 2007 04:09 AM
crxgator
Honda Fit
25
May 19, 2007 02:34 PM
t o m
Honda S2000
37
Mar 18, 2005 06:35 PM
jeremy.
Jun 20, 2004 10:28 AM
Mr.Integra
Aug 20, 2003 05:43 PM
