Help with EK hatch suspension.
Just bought a 99 ek hatch and need help with the suspension. I thought about buying a 99 si front and rear sway bars, lca, and etc to improve the handling. Does anyone have a better opinion? should i go for aftermarket than oem parts?
You're on the right track.
My only suggestion, find a different rear sway bar. The Si bar is really really small. You should get an ITR bar with a beaks kit.
My dream suspension setup:
(97 hatch)
26mm SI front sway (you need LCAs and dampening forks)
22mm USDM ITR rear sway w/ beaks kit [ http://www.beaksproducts.com ] (you also need SI endlinks)
Mugen front/rear upper strut bars
Spoon front/rear lower tie bars
Tein's (Any kind will suit MY driving style)
Bridgestone Potenza Pole-Position S-03s (I think tires are important)
SRR LCA's (If I ever break mine)
:D
(97 hatch)
:D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x00gsr »</TD></TR><TR><TD CLASS="quote">Sounds good. My budget I should say about 1k. Is it worth getting comptech kit, its a bit pricy.
IMO, it's worth it. my friend's run it and they love it. prevents the subframe from getting torn. from what i've heard, the beaks kit is also good. i'd also recommend getting a good spring/shock setup...maybe ground controls w/ koni yellows or the tein ss'.
</TD></TR></TABLE>IMO, it's worth it. my friend's run it and they love it. prevents the subframe from getting torn. from what i've heard, the beaks kit is also good. i'd also recommend getting a good spring/shock setup...maybe ground controls w/ koni yellows or the tein ss'.
LSVTEC96HB
Suspension & Brakes
16
Nov 24, 2011 03:36 PM
monEmakindave
16
Feb 2, 2011 11:02 AM
...and you get some purple bling
