Spark Plug Torque Spec please for G3 GSR
Old Jul 11, 2001 | 03:26 PM
berkel's Avatar
Default Spark Plug Torque Spec please for G3 GSR
Thanks much!
FB
Old Jul 11, 2001 | 03:46 PM
berkel's Avatar
Default Re: Spark Plug Torque Spec please for G3 GSR (berkel)
Ohh,
And how do I adjust if I have like a 6 inch extension?
Thanks,
FB
Old Jul 11, 2001 | 03:49 PM
keys's Avatar
i'm pretty sure it's 13.2 ft/lbs... someone please validate my answer
Old Jul 11, 2001 | 03:56 PM
Mr. Choi's Avatar
New User
Default Re: Spark Plug Torque Spec please for G3 GSR (keys)
my friend with a 95 gsr looked around and got an answer of 21. ft lbs. i think he called honda or something. so you can torque it down to around 20 ft. lbs with a torque wrench or you can jus turn the spark plug with a spark plug socket and ratchet 1/4 in. turn after the washer on the spark plug touches the block. jus tighten that **** down so it wont come off and also not too tight that it'll strip the threads out.
Old Jul 11, 2001 | 04:03 PM
bigD's Avatar
Default Re: Spark Plug Torque Spec please for G3 GSR (ChoisVTEC)
I always do 13 or 14 ft/lbs.
Old Jul 11, 2001 | 05:27 PM
stick's Avatar
Default Re: Spark Plug Torque Spec please for G3 GSR (2000-B18C1)
according to helms
156 in lbs
Old Jul 11, 2001 | 05:55 PM
berkel's Avatar
Default Re: Spark Plug Torque Spec please for G3 GSR (stick)
Thanks fellas!
I always used that 1/4 turn more once washer hits technique, but I got a torque wrench now, heh.
I threw away my directions for the TQ wrench, but you're supposed to set it lower when you use the extension since you have a bigger lever or whatever the physics/engineering behind it is. Maybe it's 21, but you set the wrench to 13 with the extension?
FB
Old Jul 11, 2001 | 06:19 PM
berkel's Avatar
Default Re: Spark Plug Torque Spec please for G3 GSR (Jay D Em)
Yeah,
That makes sense. I just remembered something from when I skimmed the directions
Thanks for the tip on storing the wrench on a low setting, but I did know that already, hehe.
FB
Old Jul 11, 2001 | 10:14 PM
The Mick's Avatar
Hey Franz,
Since you've already gotten the correct answer, let me give the DFH Smartass answer... torque it 'til it breaks, then back off about a 1/4 turn. Kinda like that strut tower thingy, right? Was that before or after you developed the massive forearms? J/K
Take care,
Old Jul 12, 2001 | 04:04 AM
berkel's Avatar
Default Re: Spark Plug Torque Spec please for G3 GSR (The Mick)
LOL,
I'm just starting to bulk back up after driving the cushy Audi for 1.5 years, so I'm prob not going to break any bolts soon, heh.
Take care,
FB
Old Jul 12, 2001 | 07:31 AM
96IntegraLS4DR's Avatar
And extension should not change the torque setting on your torque wrench. (no adjustment needed)
Adjustment is when you use the torque wrech with "crow foot" since the radius has changed.
Everyone - feel free to add and/or correct the 2 sentences above.
Thanks,
Old Jul 12, 2001 | 08:28 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Fran - I just hand tighten it and then snug it down to about a 1/4 turn more. It's worked for every car I've ever owned.
I wouldn't think it would matter much unless you are trying to index your plugs.
[Modified by Gee3, 9:29 AM 7/12/2001]
zach1288
Aug 5, 2019 05:10 AM
kornerk12
10
Apr 2, 2011 06:03 PM
Coltmorris
Nov 5, 2005 01:53 PM
TimsTeg
Apr 20, 2003 08:55 PM
Mike813
Apr 20, 2003 08:21 PM
