Tools for valve adjustment
Old May 20, 2003 | 03:04 PM
DC2NING's Avatar
Default Tools for valve adjustment
Can someone list all the tools I would need to do a valve adjustment for a GsR?
Also, anyone know a site with pictures to do a valve adjustment??
Old May 20, 2003 | 03:05 PM
gsxr's Avatar
Default Re: Tools for valve adjustment (DC2NING)
http://www.bseries.net
Old May 20, 2003 | 03:20 PM
P1mpSlap's Avatar
Get that Snap-on tool. OMG makes life so much easier.
Old May 20, 2003 | 03:32 PM
Aaron M's Avatar
Default Re: (P1mpSlap)
snap-on
feeler guages
basic tool set
hondabond
replacement gaskets(optional)
helms manuel
Old May 20, 2003 | 03:33 PM
threatcon13's Avatar
New User
Default Re: (SilverB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">snap-on
feeler guages
basic tool set
hondabond
replacement gaskets(optional)</TD></TR></TABLE> helms manual would be helpful too
Old May 20, 2003 | 03:38 PM
Aaron M's Avatar
Default Re: (Threatcon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote"> helms manual would be helpful too </TD></TR></TABLE>
i said that
Old May 20, 2003 | 03:45 PM
tilt's Avatar
You want angled feeler guages for the gsr. The straight ones will be a hassle to do properly.
Old May 20, 2003 | 03:46 PM
Aaron M's Avatar
Default Re: Tools for valve adjustment (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">You want angled feeler guages for the gsr. The straight ones will be a hassle to do properly. </TD></TR></TABLE>
you can find these at sears for $7
DC2NING's Avatar
where can i get the hondabond and what is it actually??
Old May 20, 2003 | 03:48 PM
Aaron M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2NING &raquo;</TD></TR><TR><TD CLASS="quote">where can i get the hondabond and what is it actually??</TD></TR></TABLE>
its a liquid gasket used to seal the valve cover.
it can be found at a honda dealer for about $12
Old May 21, 2003 | 07:06 AM
B U N M A N G O's Avatar
helms manuel</TD></TR></TABLE>
I think a Helms Carlos or a Paco would be better
I went over to watch integobsession and pdcdragon check the valves on integobsession's GSR yesterday... seems easy enough.
Old May 21, 2003 | 07:51 AM
tC_Dragon's Avatar
Default Re: (bunmango)
if you are lookin for some sites to see photos of the process you can go to the article in team-integra.net or http://www.c-speedracing.com/howto.php
Old Jun 3, 2003 | 12:09 PM
igotyofire's Avatar
Default Re: (pdcdragon)
wheres the best place to pick up that snap on tool that made for doing valve adjustment on hondas
Old Jun 3, 2003 | 12:16 PM
Aaron M's Avatar
Default Re: (igotyofire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">wheres the best place to pick up that snap on tool that made for doing valve adjustment on hondas
http://www.snap-on.com/
Old Jun 3, 2003 | 12:20 PM
igotyofire's Avatar
guessing angled for the b16 too.....also whats the part number for the snap on tool
Old Jun 3, 2003 | 12:46 PM
Zulu888's Avatar
Default Re: Tools for valve adjustment (igotyofire)
i'm confused about this valve adjustment thing, when your using the feeler guages to feel, what exactly are you feeling for? and how do u adjust??
all it says on c-speed and bseries is that there is enough drag or something, what exactly does this mean?
Old Jun 3, 2003 | 01:16 PM
mickey513's Avatar
Default Re: Tools for valve adjustment (Zulu888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zulu888 &raquo;</TD></TR><TR><TD CLASS="quote">i'm confused about this valve adjustment thing, when your using the feeler guages to feel, what exactly are you feeling for? and how do u adjust??
all it says on c-speed and bseries is that there is enough drag or something, what exactly does this mean?</TD></TR></TABLE>
I like to know too....kind of vague explanation on c-speed
Old Jun 3, 2003 | 02:17 PM
tC_Dragon's Avatar
Default Re: Tools for valve adjustment (mickey513)
the feeler guages are nothing more than small thinly cut strips of metal that have their thicknesses printed on them... you use them to check or "feel" for the amount of clearance or gap you have and if ur wondering where the gap is... well c-speed does have some decent pictures and if u want to see more feel free to to go my site and u can see what it looks like on an LS motor which is similar although not identical. oh go to the diy section of my site and click on valve adjustment
EDIT: as for explaining how u adjust it, well again if u go to my site u can see pictures of teh lock nut and adjusting screw. YOu must loosen teh lock not so that u can adjust the screw. Once the nut is loosened, you can turn the screw to adjust the clearances, clockwise to lessen the gap and counter-clockwise to increase the gap. Does that make sense at all?
Old Jun 3, 2003 | 03:01 PM
Brett's Avatar
Default Re: Tools for valve adjustment (pdcdragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdcdragon &raquo;</TD></TR><TR><TD CLASS="quote">the feeler guages are nothing more than small thinly cut strips of metal that have their thicknesses printed on them... you use them to check or "feel" for the amount of clearance or gap you have and if ur wondering where the gap is... well c-speed does have some decent pictures and if u want to see more feel free to to go my site and u can see what it looks like on an LS motor which is similar although not identical. oh go to the diy section of my site and click on valve adjustment .... etc.
beautifully explained
anyone have the part # for the snap-on tool?
Old Jun 3, 2003 | 03:20 PM
tC_Dragon's Avatar
Default Re: Tools for valve adjustment (Brett)
well this is what i came up with on snap-on.com its called a " Tool, Metric, Valve Adjustment (for cars with 10 mm jam nut valve screws) "
found under "Catalog Index &gt; Valve &gt; Metric Jam Nut-Type Adjustment Tools &gt; Metric Jam Nut-Type Adjustment Tools "
and "Stock NO:YA8895 "
hope that helps.
EDIT: try goin here http://buy.snapon.com/catalog/...store
Old Jun 3, 2003 | 04:44 PM
Aaron M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdcdragon &raquo;</TD></TR><TR><TD CLASS="quote">well this is what i came up with on snap-on.com its called a " Tool, Metric, Valve Adjustment (for cars with 10 mm jam nut valve screws) "
hope that helps.
EDIT: try goin here http://buy.snapon.com/catalog/...store </TD></TR></TABLE>
where have you been bro!!
is it 10mm or 12mm though?
Old Jun 3, 2003 | 06:16 PM
acatak's Avatar
Default Re: Tools for valve adjustment (SilverB18C1)
do a search before you post a topic like this. IT has been covered 14,654 times
Old Jun 3, 2003 | 08:50 PM
tC_Dragon's Avatar
is it 10mm or 12mm though?</TD></TR></TABLE>
yo watup aaron, yea i've been MIA for a while huh?
as for what size it is, after checkin couple sites, i gather that its
10mm for b18c's (Pretty Sure)
12mm for b18b (FOR SURE!)
B18C Turbo
Honda S2000
14
Nov 27, 2007 07:06 PM
LudaChris
Oct 19, 2006 08:37 PM
Clairvoyant
Jul 3, 2006 06:13 PM
1JDMDOMINICAN
Apr 15, 2006 05:32 AM
crxracer2
Jan 12, 2005 07:00 PM
