What axles do I use when swaping a b16a in a 91 civic si?
Old May 20, 2003 | 02:43 PM
Coricivic's Avatar
Default What axles do I use when swaping a b16a in a 91 civic si?
I have looked on a bunch of sites and I'm not sure what axles to put on.
Old May 20, 2003 | 02:52 PM
Malgerus's Avatar
Default Re: What axles do I use when swaping a b16a in a 91 civic si? (Coricivic)
In most cases 90-93 teg axles, Non abs work prefectly fine. Or the JDM axles, if they come with your swap.
Be sure to remove the dust shields, and any rings that come on the axles if you buy them.
Old May 20, 2003 | 07:34 PM
CRXBart's Avatar
It depends on the tranny that comes with your swap. Check Hasport.com they cover it there. With a S1 tranny you just remove the dust sheilds and the caps for the sheild on the inner lip of the spindal.
Old May 20, 2003 | 10:02 PM
Adam F's Avatar
Default Re: What axles do I use when swaping a b16a in a 91 civic si? (CRXBart)
with the Place kit I always used 86-89 acura integra axles
Old May 21, 2003 | 06:16 AM
Cory man's Avatar
Default Re: What axles do I use when swaping a b16a in a 91 civic si? (Proelite103)
If you get a 90-93 teg intermediate shaft you can use 90-93 teg axles. Just remove the dust shields and plastic rings on the axles.
Old May 21, 2003 | 06:45 AM
wickedEFguy's Avatar
it depends on what kind of half shaft you have and also what kind of tranny your getting as well, here's more info
http://www.hasport.com/News/Ar...s.htm
Old May 21, 2003 | 08:29 PM
AdamBOMB_STi's Avatar
Default Re: What axles do I use when swaping a b16a in a 91 civic si? (Ninja_Jc7)
im running Driveshaft Shop Stage 1 Cro-Moly axles. i had stock sir axles but i broke 2 u joints. the DSS axles are nice and beefy and i think im gonna have a very hard time breaking these.
the_rex
Mar 23, 2008 07:44 AM
b18crx
May 26, 2003 06:28 PM
Eggman
Feb 8, 2002 10:45 AM
89sir-9
Nov 23, 2001 08:29 PM
