B18B v-tech
Vtech's last a pretty good length of time. Mine seems to "crackle" if I walk far from the base, even with the antenna all the way up. But it's all good, I mean damn, it's better than a cell phone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonBlackEJ1 »</TD></TR><TR><TD CLASS="quote">no such thing as a 93 si coupe bud. </TD></TR></TABLE>
I'll bet you 10 bucks....I see them all the time since I live 20 miles from Canada
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pete_SI »</TD></TR><TR><TD CLASS="quote">I was wondering if you could put a a non v-tech engine like the b18b a v-tech and if so is it harde and does it last or does it just blow.</TD></TR></TABLE>
i dont really understand what you were trying to write there.
but if you mean ls/vtec yea. oh yea check your spelling for vtec, not "vtech" which is a telephone company.
but you can have vtec on a b18b if you take the head off that block and add a vtech head such as b16's and b18's. they add good hp and torque numbers. but if you dont know what you are doing then make sure their is a shop that does.
but this job does not come by cheap.
hope this info helps.
Try a search on "LS-VTEC" and "LS/VTEC" and "LSVTEC." Search recent topics and archives, in this forum, the Tech forum, and the Hybrid forum. There is a ton of information around here on building LS-VTEC engines.
To put it bluntly, you can't just bolt a VTEC head to the non-VTEC block, and expect it to last more than 30,000 miles or so; the engine geometry of the B18A/B isn't well suited for a high-revving VTEC engine. I highly recommend having the engine's bottom end built up beforehand.
Good site for LS-VTEC information: http://www.oretek.co.za/honda%...c.htm
By the way, it's VTEC, not v-tech. It's an acronym, not a "tech."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kikiboi »</TD></TR><TR><TD CLASS="quote">
hope this info helps.</TD></TR></TABLE>
You ******* tool, you actually spelled it v-tech. You don't deserve to drive a Honda.
Learn how to operate this first before getting behind the wheel of a car.
those vtech heads sure do help them hp and tq numbers don't they
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A2-EM1 »</TD></TR><TR><TD CLASS="quote">
haha
</TD></TR></TABLE>haha
You have alot to learn. Try the spell check also next time. I'm assuming you were referring to a LS/Vtec. Use the "SEARCH" it helps of preventing from getting flamed.
