00 Si brakes -> 92 Si HB
Hey folks:
Well, i have the front knuckle (whole assy, knuckle, rotor, caliper) from a 00 Si coupe on the car right now. I even swapped the rears, hooked up the ebrake and bled almost two bottles of motul through the system.
Problem is: brake pedal goes to the floor when the car is runnin and barely actuates the calipers. The suspension came off a friends totaled car and sat under a tarp for about 5 months. Think I need to rebuild/service the caliper? Will it work if i do? Im concerned that its the master cylinder, i.e. not enough to apply enough pressure to all 4 corners.
Current setup:
Rear: whole 00 Si assy, with integra LCA's
Front: stock except for 00 Si knuckle assy + rotors + calipers
Fresh pads and motul 600 fluid
Thanks eg6ajk to for all his help thus far,
Demian
Current setup:
Demian
Redz_EX
May 12, 2007 05:29 PM
