what sould be done with timing belt change other than WP??
Old May 20, 2003 | 12:30 PM
stock97's Avatar
Default what sould be done with timing belt change other than WP??
what else should i have done whan i take my car in?
Old May 20, 2003 | 12:40 PM
JLange's Avatar
Default Re: what sould be done with timing belt change other than WP?? (stock97)
timing belt tensioner
Old May 20, 2003 | 12:47 PM
stock97's Avatar
Default Re: what sould be done with timing belt change other than WP?? (jtintegra)
opps i forgot to add that and acc. belts
but anything else while they are in there?
Old May 20, 2003 | 01:06 PM
dip-set's Avatar
valve adjustment
Old May 20, 2003 | 01:43 PM
Comp97GSR's Avatar
Default Re: what sould be done with timing belt change other than WP?? (teg-your-it)
If we can talk you intodoing it yourself, I would say a case of beer (only after you torqued the tensioner are you allowed to drink heavy). I did it Sunday and it wasn't hard, just time consuming.
Old May 20, 2003 | 06:53 PM
stock97's Avatar
Default Re: what sould be done with timing belt change other than WP?? (Comp97GSR)
ok seriously on a scale of 1 - 100 what would you rate it as far as difficulty?
would it be compareable to brakes or a radiator change? cuz i've done those myself with little or no trouble, cept for busted knuckles n ****, also what are the chances of me breaking **** cuz i definetly need to have my car (and be able to sell it soon to get a better <5speed> one)
Old May 20, 2003 | 09:27 PM
conesmasher's Avatar
IMO I would rather pay someone to do my timing belt, just incase something happened, I could blame someone else instead of myself.
Old May 20, 2003 | 10:46 PM
IN VTEC's Avatar
I'd say about a 5.
I'd take a timing belt and water pump any day over a clutch/flywheel swap and/or cracking the tranny case. Even then, I'd only give it a 6.
Old May 21, 2003 | 06:45 PM
red alert's Avatar
Default Re: what sould be done with timing belt change other than WP?? (IN VTEC)
since your already down there why not replace all the belts ac, power stearing, alternator, and water pump , it sucks to have to go back and do it all
Old May 21, 2003 | 07:19 PM
stock97's Avatar
Default Re: what sould be done with timing belt change other than WP?? (red alert)
a 5 or 6 out of 100 or out of 10?????? (huge difference)
i also was thinking that if i take it to someone i am not responceable for anything but the bill, so if they break it they buy it
Old May 21, 2003 | 10:31 PM
IN VTEC's Avatar
Out of 10.5521.
ginahoy
Sep 1, 2014 05:02 AM
chahsiubow
Dec 14, 2007 10:01 PM
BlackGser
Apr 27, 2005 11:00 AM
intezn
Nov 10, 2002 10:47 AM
