60K maintenance on GSR
Old Jul 11, 2001 | 11:28 AM
leesiulung's Avatar
New User
Default 60K maintenance on GSR
man my dealer charges me $530 for the 60k mile maintenance!! what a ripoff... how mcuh does it charge other place any1 know?
-siu lung
Old Jul 11, 2001 | 12:10 PM
JL 74's Avatar
Default Re: 60K maintenance on GSR (leesiulung)
what kind of work needs done?
Old Jul 11, 2001 | 02:52 PM
DOHC_VTEC786's Avatar
New User
I assume they are doing a T-Belt + the service but 530 is alot of money....go find out what they are charging you for? breakdown what they are charging you for then go a different dealer and see what they want to charge for the same service. I did that and found myself going to a overpriced dealership that was charging me much more for the service than other dealers. Also see if the honda dealership will do the service on your gsr they charge was less than acura
HTH
Old Jul 12, 2001 | 11:14 AM
leesiulung's Avatar
New User
Default Re: 60K maintenance on GSR (jl74)
all of whatever the manual suggests!! Most of it is check this, check that, bla bla bla. Only thing I can see in there that actually get done is the air filter, spark plugs, and changing out coolant.
and no the timing belt is separate it cost $515, which is a freakin rip off!!
-siu lung
Old Jul 14, 2001 | 12:28 AM
ninjaman's Avatar
New User
I thought it included the timing belt Anyhow, to give you an idea, my dealer quoted me for $183 for the timing belt (including the belt) The 60k should also include a valve adjustment in addition to all the fluid and minor adjustments. I'm sneaking in my new cams and valve springs with the valve adjustment. Timing belt, cams, valvesprings, and water pump labor is going to run me $462. (Not at the dealer though becuase they wanted to take the head off to do my valve springs)
Old Jul 14, 2001 | 04:31 AM
stick's Avatar
timing belt is not recommended until 90K along w/ water pump
i would definitely go to other dealers and see what they charge.
some things u can do yourself and save money
Old Jul 14, 2001 | 10:24 AM
mickey513's Avatar
You got ripped.............
Old Jul 14, 2001 | 03:14 PM
Rory Breaker's Avatar
Default Re: 60K maintenance on GSR (mickey513)
Ive gotten quotes around $500 as well...thats usually the norm from what Ive experienced!! $183 is a steal!
I would tackle the 60k maintenance myself if I were you...invest $60 in a Helms manual and go to town...nothing should be too difficult.
Old Jul 14, 2001 | 03:57 PM
fixhondas's Avatar
We (dealer) charge around 300$ for a 60k plus around 40$ if a cap and rotor is needed. We do valve adjustment, brake/clutch fluid chg, trans fluid chg, oil chg, check/ adjust brakes, change plugs(not platinum), air filter, fuel filter (if required).
B serious
Jan 25, 2007 04:05 AM
ArizSun21
Nov 12, 2003 01:56 PM
Keane Rated R
Dec 5, 2002 02:32 AM
thebigbirdstyle
Nov 27, 2002 10:44 AM
Racer
Dec 5, 2001 07:03 PM
