TDC on crank w/o pulley on for b16
Old May 20, 2003 | 07:42 AM
pokemon's Avatar
Default TDC on crank w/o pulley on for b16
I heard that if you align the "key" with the arrow on the block that that is TDC is this true? The motor is out of the car also..
Old May 20, 2003 | 07:48 AM
slowpokesi's Avatar
Default Re: TDC on crank w/o pulley on for b16 (pokemon)
nope it isnt true
Old May 20, 2003 | 07:52 AM
pokemon's Avatar
How can I time it then with the crank pulley off the motor?
Old May 20, 2003 | 07:55 AM
b18cvtec's Avatar
get yourself a crank pulley or do you want to run the risk of throwing something because the timing was off more than 12 degrees.
Old May 20, 2003 | 07:57 AM
pokemon's Avatar
I got a crank pulley but there are no timing marks on it, that is why I am asking this question... thanks.
Old May 20, 2003 | 08:38 AM
slowpokesi's Avatar
Default Re: (pokemon)
turn the crank until your cam gear marks are pointing at each other like this, they should be exactly even, and then the the aarows should be pointing up. when you get this car back in you need to go get a timing gun.
what crank pully are u using?
chope045
Mar 30, 2011 11:16 AM
red civic standard
Sep 27, 2004 09:02 PM
Nextelbuddy
Mar 29, 2004 11:43 AM
DOHC_C-REX
Mar 24, 2004 11:51 AM
