b18c1 radiator hoses n stuff
Old May 19, 2003 | 10:07 PM
TurboTeG4's Avatar
Default b18c1 radiator hoses n stuff
Will the b18c1 radiator hoses fit on my pwr radiator on my 93 coupe??
Also when putting in the p72 when i swap i currently have a vafc hooked up to my p28 will any of my wires have to modified from the vafc or do i just leave it hooked up. I already cut my harness to put the greddy blue box(fmu) then cut more for my vafc so its hacked up a bit!! Thinkin bout gettin engine from hmotorsonline is all there motors clean!
Old May 20, 2003 | 06:00 PM
TurboTeG4's Avatar
Default Re: b18c1 radiator hoses n stuff (turbocivic4)
bump for my silly post, n i called hmotorsonline, shoudl i get a obd1 swap or a obd2 swap for my 93 coupe. I think if i put a newer engine for the same price the better huh only need additional 200 for the obd1 ecu???
Old May 20, 2003 | 06:30 PM
Lord Helmet's Avatar
go with the obd1 then obd2 since you have a obd1 car in the first place and less headache too. smog ref will certainly get on your *** if you don't have all the obd2 smog equipment on.
Old May 20, 2003 | 07:09 PM
TurboTeG4's Avatar
Default Re: b18c1 radiator hoses n stuff (sleeperciv)
I just ordered a 1995 gsr complete swap from Steve, i hope my pwr radiator will not be problem. Also will the vafc be a problem or does the wires just stay where they are on my ecu, dam now i need a b18c1 msd ditributor cap
Old May 20, 2003 | 07:16 PM
TurboTeG4's Avatar
oh does my nology ignition wires on my sohc be put on the dohc is it long enough>?
Old May 20, 2003 | 07:43 PM
TurboTeG4's Avatar
What bracket do i need to put my ac on the gsr motor???
Lot of questions i have huh?
Answers are welcome!!!!!
too much to search for these answers
Old May 20, 2003 | 07:47 PM
IS3Fifty's Avatar
no your hoses will be too big
go OBD1, run hondata or other engine management
and del sol brackets for AC
Old May 20, 2003 | 08:37 PM
TurboTeG4's Avatar
Default Re: b18c1 radiator hoses n stuff (TODAeg6)
omg ur tellin me i need another freakin performance radiator this sux big time and the vafc wires??Dont got money for stand alone crap this is breakin my bank. Is there a way to mod my pwr radiator for 93 civics to run with the gsr swap?
Old May 20, 2003 | 10:47 PM
TurboTeG4's Avatar
94 sol vtec -lower hoses
94 gsr upp hose
fits stock
brotech
Dec 20, 2005 09:21 AM
otakueric
Mar 2, 2004 09:57 AM
tuan...
Feb 7, 2004 09:07 PM
