clutch squeeks when i press it... is it the MC?
when i depress the clutch, it squeeks. i think my master cylinder leaks, cuz i get a little fluid behind the clutch. im pretty sure its the master cylinder, but wanted some reassurance. now what i really want to know is will a integra MC fit in my 92-95 civic?
EG clutch master cylinders are known to leak....mine does I need to replace it...the squeeking is either the moving parts of the pedal, grease those babies up, if not its your TOB but you'd hear that with your window open only......
I don't believe the teg one will work...diff part numbers..
clutches dont have master cylinders. those would be SLAVE CYLINDERS. Master Cylinder is brakes. the clutch still uses brake fluid, just not as much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nemesismachine »</TD></TR><TR><TD CLASS="quote">clutches dont have master cylinders. those would be SLAVE CYLINDERS. Master Cylinder is brakes. the clutch still uses brake fluid, just not as much.</TD></TR></TABLE>
You're kidding right? what do you think that little resevior is next to the brake M/C? you know the one with the little hose that runs down to the CLUTCH M/C!!!!
You should really know what you're talking about before you post.
no more
for you dawg!!!!!!!
Yes they do have M/C's!!!
I'm on the same boat, I found a good M/C on nopi, but they are out of stock, autozone wants like 140 or so for a new one and that special order...nopi's was like 42 shipped........How easy is it to change?? since I"m bleeding the lines afterwards should I add a SS clutch line???
for you dawg!!!!!!!Yes they do have M/C's!!!
ozh_hawaiian
Dec 3, 2011 03:28 PM
vlc92189
Nov 6, 2006 08:49 AM
