moroso oil pan
Old May 19, 2003 | 08:00 PM
spoolinlude's Avatar
I live under a rock
Default moroso oil pan
I got the moroso oil pan today..... its a beast.... here's my hopefully not huge problem.... I had a bit of a relapse and realized i have a h23 bottom end, the pan says it fits 2.2 and 2.3 motors....... are they the same??? i sure as hell hope so, i don' have a 2.2 pan to compare my 2.3 to
Old May 19, 2003 | 08:02 PM
str8rcn's Avatar
Default Re: moroso oil pan (spoolinlude)
2.2 and 2.3 blocks are the same outer dimensions and the pan does fit both.
Old May 19, 2003 | 08:06 PM
I live under a rock
Default Re: moroso oil pan (str8rcn)
thank you jesus.... i was about to flip the hell out...... one more totally stupid question thou..... can i use my stock pickup, i relapsed again and forgot to order the damn moroso one......problem?
Old May 19, 2003 | 08:21 PM
str8rcn's Avatar
I think you can use the stock pickup.They only "recommend" using theirs as if $400 isnt enough of your money already.
Old May 19, 2003 | 09:03 PM
h23atsi's Avatar
the moroso oil pan was specifically made for the 4th gen so it should fit nicely. keep us updated on that pickup. i'm about to order my pan and need to know if i need the pickup.
Old May 27, 2003 | 06:24 PM
I live under a rock
Default Re: (h23atsi)
YEP u need the pickup, thought i wouldn;t need it but i was wrong.... its not only lower..... its about 3 inches moved to the left!.... so don't forget to order it w/ the pickup..... like i DIDN;t..... o well, should be up n running by friday!
pacmann_9595
Aug 19, 2007 04:19 PM
lude98SH
Apr 19, 2007 07:03 PM
huntarrr
15
Mar 15, 2006 08:36 AM
ih8sndq
Jun 26, 2005 05:59 PM
