anyone with idle troubles from a zdyne ecu
Anyone ever had an idle problem with their zdyne? I emailed the company but I don't think i'll ever here back from them. I installed the 3bar map sensor in parallel with my stock sensor and made nice soldered connections. I'm not currently using the 3bar map sensor but its unplugged. My car was idling great with the si (pm6) ecu. its also giving me a code 8 and i just replaced the distributor (dizzy, for some reason its called this on this site) and got rid of a code 9. My RPM's will drop to 250 or so when i let off the gas, and it seems to change when I release the clutch. Thanks guys
im running a zdyne gold secu on my b20turbo with a pr4 (LS) program and it has a rough idle unless i give it some gas off a cold start but that is because of my 450cc's and a rich fuel curve i have.... but when i ran it stock it ran as if nothing was even done so it must be something stupid like timing or worn parts... hell even something that everyone overlooks when you change your oil last that stuff could be tar you never know... if its like my car look at the stupid stuff first, i key thing for some reason if you dont use honda wires ( pepboys or some cheap brand) make sure they dont touch or else they my cross arch that was a problem i had before. other than that just start to elimainate things to narrow it down.
92eg6_pino
Aug 16, 2005 07:53 PM
machine4321
31
Jul 10, 2004 08:16 PM
