What Brake Upgrade Set-up are you guys using?
I have the good fortune of having an Si with stock four wheel discs. All I have done is Brembo blank rotors and EBC Green Stuff pads in the front and Red Stuff pads in the back. I also have SS brake lines that are sitting in my apartment (and not on my car
powerslot fronts and nissin/aem pads
plain old stock drums in the rear (as soon as the money rolls in swappin for discs as well)
I have the Baer Track front kit, consisting of 13" rotor and huge two piston PBR caliper. In the rear is the Baer Touring kit which is a 12" rotor and a smaller single piston PBR caliper. No more parking brake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote"> No more parking brake.</TD></TR></TABLE>
Race only? Otherwise how do you keep the thing where you left it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy »</TD></TR><TR><TD CLASS="quote">well currently on my 93 hatch i have complete front and rear gsr brake system and it stops great</TD></TR></TABLE>
how much did that cost you??? cause my friend said he would give me full gsr suspension with disk brakes for 6bills...is that a good deal???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piscorpio »</TD></TR><TR><TD CLASS="quote">
Race only? Otherwise how do you keep the thing where you left it?</TD></TR></TABLE>
Park it in first gear....and stay away from step hills.
My car is daily driven street car.
Race only? Otherwise how do you keep the thing where you left it?</TD></TR></TABLE>Park it in first gear....and stay away from step hills.
you can sometimes find the complete gsr suspension w/booster&mc for around $600.
I'm running with stock 98ex front setup, brembo blanks w/aem pads. '00 SI rear discs, powerslots w/aem pads. Also using ATE Type 200 brake fluid.
You given any thought to going for an EX front setup and GSR/SI rear setup? Might be quite a bit cheaper than a GSR setup. The EX/SI fronts are the same and only diff between EX/SI and GSR fronts is the GSR calipers are slightly bigger.
speaking of fastbrakes, here's my front setup....
http://pictures.sprintpcs.com/...0,0,0
keep getting red x's if I put in image tags. anyone get it to work let me know. By the way this pic is from my phone....
Modified by superflea at 5:12 PM 5/21/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">http://www.fastbrakes.com</TD></TR></TABLE>
12.2 inch wilwood 2 piece rotor, wilwood 4 piston caliper, wilwood s.s lines and a 99 civic si master cylinder. Bought it from overboost.com.
Ha ha. I would prefer to keep my 15" wheel set-up so that limits my big brake options. Does any company sell a complete GSR kit w/instructions? Looks like these come up pretty often on ebay but I want to be sure I have all of the pieces.
I am using full GSR setup with upgraded crossdrilled rotors in front. still don't stop fast enuff for me. i'm considering upgrading to AEM or Tenzo R big brake kit. Can't afford the good stuff like Wilwood.
6 bills is way to expensive. I got my GSR brakes plus M/C, booster, and prop for 350$. Look around and you can find a deal.
I also have cobalt friction rotors and axxis ultimate pads.
