B20Z head on B18A
Old May 19, 2003 | 07:34 PM
LegoZ81's Avatar
Default B20Z head on B18A
If this will work I need to know what I will need to do this swap. I would also like to be clued into what is different (ie are the cams the same or are they a different grind)
The water holes are in a different place or something i hear so can I just use a B20Z head gasket and bolt it up to the B18a?
The reason for this swap is not a power getter it is b/c my B18a head has some issues which include a rocker arm that got thrown from one side of the head to the other (ie it's loose now i can't give pics cause clubphoto is down for me sorry)
and by the time i replace the rocker arm and get a valve adjust i'd be better off getting this other head (cheaper and seems to be in much much better shape).
I am tired so this is probablt babble lmk if i need to clarify my ?'s
Thanks
LEgoZ
Old May 19, 2003 | 09:49 PM
One Bad GeeSeeR's Avatar
Default Re: B20Z head on B18A (LegoZ81)
yes it will work just swap over your obd-0 equipment to it. and use a b18a headgasket.
Carlo
Old May 20, 2003 | 06:05 AM
LegoZ81's Avatar
Default Re: B20Z head on B18A (ChampwhiteSi)
Cool Thanks for the help.
iheartjayDem
Jul 10, 2009 03:34 AM
chriskuipers
May 8, 2007 07:46 PM
lscrxhf
Apr 15, 2006 05:10 PM
