someone double check me on these bearings colors
Old May 19, 2003 | 06:19 PM
ludesleep's Avatar
Default someone double check me on these bearings colors
this sound right...main bearings from timing belt sideover..c3(green),c3(green),c2(yellow/green),c2(yellow/green),c3(green)
ROD bearings same way...c3(brown),c3(brown),c3(brown),c3(brown)??
Modified by ludesleep at 3:59 AM 5/20/2003
Modified by ludesleep at 4:09 AM 5/20/2003
Old May 19, 2003 | 07:00 PM
ludesleep's Avatar
Default Re: someone double check me on these bearings colors (ludesleep)
anyone?
Old May 19, 2003 | 08:16 PM
paul9luap's Avatar
We had the same problem on the same day. https://honda-tech.com/zerothread?id=510136 . I was at the local honda dealer today, and here's what we determined, starting from the timing belt side, going right to the flywheel side. We used the "34334" stamped on the block, with the "33223" from the crank.
There should be 5 sets of main bearings, totaling 10 bearings. There should be 4 sets of rod bearings, totaling 8.
MAINS: green/green - green/brown - yellow/green - yellow/green - green/brown
RODS: yellow/yellow -- yellow/yellow -- yellow/yellow -- green/green
Modified by paul9luap at 12:30 AM 5/20/2003
Old May 19, 2003 | 08:17 PM
Prelude Vtec 23's Avatar
For the rods you use the number on the rod and the letters on the crank.
For the main bearings, there are numbers or letters or bars stamped on the block itself, use that plus the numbers on the crank.
Is that what you did to determine the sizes? If so then your ok.
Old May 19, 2003 | 08:35 PM
ludesleep's Avatar
Default Re: someone double check me on these bearings colors (Prelude Vtec 23)
ok the numbers stamped to my block are 2,3,2,3,4....so 2&c3=yellow/green, 3&3=green,2&2=yellow,3&2=yellow/green,4&3=green/brown..........anyone else follow or understand what the hell im talking about?
Old May 19, 2003 | 08:57 PM
the numbers on the crank is for your mains.......so your first one is 2 and 3 = yellow/green, second one is 3 and 3 which is green and so forth.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesleep &raquo;</TD></TR><TR><TD CLASS="quote">ok the numbers stamped to my block are 2,3,2,3,4....so 2&c3=yellow/green, 3&3=green,2&2=yellow,3&2=yellow/green,4&3=green/brown..........anyone else follow or understand what the hell im talking about?</TD></TR></TABLE>
Old May 19, 2003 | 09:00 PM
paul9luap's Avatar
RODS:
MAINS:
ok, ludesleep, here's what i got for you. starting from the timing belt, moving over to the flywheel side.
MAINS: yellow/green - green/green - yellow/yellow - yellow/green - green/brown
so yes, i think you're right. Man, that's weird that we both have h23's but yet we use different bearings....huh.
ludesleep's Avatar
hmm well im gonna use a plastigage just to make sure...do you perform this test with or without bearings on the parts?
Old May 20, 2003 | 01:42 AM
forcefed's Avatar
with bearings be carful not to move the rod with the platigauge in place
you guys are lucky( or maybe i'm just unlucky) my jdm motor had no markings
on it other then main codes. honda told me that "some one was lazy in the factory"
Old May 20, 2003 | 07:29 AM
flyrod's Avatar
"hmm well im gonna use a plastigage just to make sure"
Good idea. All those numbers should get you close, but you still have to check clearances!
nightscream
Feb 5, 2012 08:23 AM
hondacivic4g
Aug 3, 2007 03:42 PM
zerovandez
Mar 27, 2006 04:58 PM
zerovandez
Mar 27, 2006 03:23 PM
ludesleep
May 19, 2003 08:40 PM
