Civic SOHC need opinion!!!
Old May 19, 2003 | 04:14 PM
Pete_SI's Avatar
Default Civic SOHC need opinion!!!
Hi,
I have a 1993 civic coupe and i smokes pretty bad. I wanted to know how garde is it to put a integra motor (do i have to change my motor mount or does it just fit in) Also i have one more option, ican build my motor (1.6 SOHC V-Tech) I want to know what kind of HP would I get by boring it to 1.8L, high compresion pistons and a after market ignition.
Old May 19, 2003 | 04:24 PM
schlack's Avatar
Default Re: Civic SOHC need opinion!!! (Pete_SI)
What kind of integra motor? I wouldn't bore a SOHC it would be better if you spend your money on the integra motor in my own opinion.
Old May 19, 2003 | 04:26 PM
Neptune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pete_SI &raquo;</TD></TR><TR><TD CLASS="quote">Hi,
VTEC not VTECH, anyways you would need mounts and i would recomend just doing the swap to B18c than boring that sucker out. Or instead of boring it out, boost it!
Old May 19, 2003 | 04:27 PM
tek_civic's Avatar
search for "overbore" and you will see my thread asking about boring and such, its a little more than you think, about a grand and then you gotta get pistons and all that. no idea on power #.
Pete_SI's Avatar
I would like a GSR but its expensive when you have to go to school. I heard that just LS or GS motor in a civic do pretty good in the 1/4 mile i would like to know how harde is it to do a motor swap. Do i have have to buy new motor mount or does the motor just slide right in??
Old May 19, 2003 | 04:28 PM
moondoggy's Avatar
Default Re: Civic SOHC need opinion!!! (Neptune)
go for b18c1, alot cheaper than c5 unless you got the money to spare.
Old May 19, 2003 | 04:29 PM
vicivic's Avatar
depending on what integra motor you go with, i would get a gsr either then building the d16. but if you plan to buy a b18a, you might as well build a d16 since you get almost the same numbers without the extra weight of a the b18a. hope that makes sense.
Old May 19, 2003 | 04:34 PM
Pete_SI's Avatar
how about the B18B???
Old May 19, 2003 | 04:37 PM
schlack's Avatar
Kick *** motor for turbo thats what I would do.
SoHc Ej1
Jan 18, 2008 09:03 PM
Not2farFromtypeR
Jul 25, 2006 01:34 PM
Versatilx1
Jan 7, 2006 04:56 PM
Pete_SI
May 20, 2003 07:57 AM
