Need to know if my JDM B18c-R is the real thing!!!!
Old May 19, 2003 | 04:10 PM
mkhooaah's Avatar
Default Need to know if my JDM B18c-R is the real thing!!!!
Hey guys,
I know this isnt the CRX forum, but I figured you guys would be the best ones to ask. I just got my 89 Crx w/JDM B18c-R in it. Just would like to make sure it is the real thing...........thanks alot.
[IMG]"C:\My Images\b18cspecr.JPG"[/IMG]
[IMG]"C:\My Images\enginebay.JPG"[/IMG]
Old May 19, 2003 | 04:11 PM
mkhooaah's Avatar
Default Re: Need to know if my JDM B18c-R is the real thing!!!! (mkhooaah)
hmm guess that didnt work out to well............
Old May 19, 2003 | 04:12 PM
acuracing's Avatar
You can't host pics from your hard drive. You have to upload them somewhere. Try http://www.we-todd-did-racing.com
Old May 19, 2003 | 04:14 PM
threatcon13's Avatar
New User
Default Re: Need to know if my JDM B18c-R is the real thing!!!! (acuracing)
just see if it says B18C, has the itr intake manifold, tranny w/ LSD , etc.
Old May 19, 2003 | 04:31 PM
jonas's Avatar
Default Re: Need to know if my JDM B18c-R is the real thing!!!! (Threatcon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote">just see if it says B18C, has the itr intake manifold, tranny w/ LSD , etc. </TD></TR></TABLE>
SiR-G also has the "b18c" stamp, itr intake manifold can be swapped in fairly easy (as well as a red valve cover), SiR-G tranny also has LSD.
look for a pr-3 stamp on the head, look for a green paint bloch near the back of the distributor, look for a JDM 4-2-1 or 4-1 header depending on year, if you want to take off the head, look for the p73-00 stamp.
all this can be swapped out/in as well, but this is just more things to look for.
Modified by jonas at 3:49 PM 5/20/2003
Old May 19, 2003 | 04:32 PM
mkhooaah's Avatar
ok this should work.....
also here are the mods ...... just if anyone was wonderin.....
JDM b18c type r motor, Jun Stage 3 cams, Crower retainers and springs, 120 psi+ Fuel pressure regulator, High Flow fuel pump, Injen Intake, DC Sports Header, Test Pipe, Tanabe G-Power racing medalion exhaust, ACT X-treme pressure plate w/ Hybrid street disc, CM Flywheel
New Cryo treated gears on transmission, Raxle Axles, Jun programmed computer, Fiber Image Carbon Fiber Hood, Nuespeed Springs on TOkico blues, Slotted Rotors, Place Racing Motor Mounts, Unorthodox Racing pulley
Old May 19, 2003 | 04:58 PM
VTEC-DA's Avatar
Not to be a dick, but you did all that to the motor and you dont even know if its the one you think it is?
Old May 19, 2003 | 04:59 PM
SlowPoke's Avatar
New User
From what I can see, it has the right intake manifold and the right engine code. The gsr in the states said B18C1 and the itr said B18c5 while in japan the ITR said B18C if I remember right. However your tranny does not seem to be a ITR tranny. Someone correct me if I'm wrong but I thought that the ITR tranny's were S80/Y80
Old May 19, 2003 | 05:04 PM
Blazeone's Avatar
that tranny has even shorter gears than the ITR tranny, i beleive the FD is 4.4..
Old May 19, 2003 | 05:05 PM
Buckshot's Avatar
Default Re: (SlowPoke)
shouldnt the valve cover have an H on it?
Old May 19, 2003 | 05:09 PM
mkhooaah's Avatar
Default Re: Need to know if my JDM B18c-R is the real thing!!!! (VTEC-DA)
I understand and know ur not tryin to be a dick but i just got this car 2 days ago from New York and just wanted to check with you guys...........thanks
Old May 19, 2003 | 06:09 PM
jonas's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowPoke &raquo;</TD></TR><TR><TD CLASS="quote"> The gsr in the states said B18C1 and the itr said B18c5 while in japan the ITR said B18C if I remember right</TD></TR></TABLE>
in japan, their GSR (SiR-G) also says "b18c" on it. read my previous post.
Old May 19, 2003 | 06:10 PM
jonas's Avatar
Default Re: (Buckshot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buckshot &raquo;</TD></TR><TR><TD CLASS="quote">shouldnt the valve cover have an H on it?</TD></TR></TABLE>
if it were a jdm valve cover, it should say
dohc
VTEC
however, like i mentioned above, that part can also be swapped out for a USDM one with ease.
Old May 19, 2003 | 06:12 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC-DA &raquo;</TD></TR><TR><TD CLASS="quote">Not to be a dick, but you did all that to the motor and you dont even know if its the one you think it is?</TD></TR></TABLE>
ha doesnt matter now, since he replaced some of the ITRs good stuff
Old May 19, 2003 | 06:28 PM
TIroneous's Avatar
Default Re: Need to know if my JDM B18c-R is the real thing!!!! (hybridvteceg)
geez, that thing is in a crx!?!!- have fun!
Old May 19, 2003 | 06:29 PM
fowler!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">
ha doesnt matter now, since he replaced some of the ITRs good stuff</TD></TR></TABLE>
Actually, it does. He still has the stock pistons.
Look at the head, behind the distributor. There should be a little part that has green paint on it. Hopefully, the previous owner didn't remove it.
Old May 19, 2003 | 09:40 PM
92TypeR's Avatar
FSAE
Default Re: Need to know if my JDM B18c-R is the real thing!!!! (fowler)
IM looks to be right. Engine code is right. I'd say it is, unless it is a skunk2 IM on a P72 head. What is the head stamp...PR3 or P72?
The reason he is using the YS1 is because the CRX is cable operated, whereas our ITR's are hydraulic. I used my gsr's YS1 back when I had my B18C-R in my '92 gsr. The gearing is almost identical to the USDM ITR, and 96-spec JDM ITR. The '98 spec JDM ITR would be shorter.
Old May 19, 2003 | 09:44 PM
2.2L EH2's Avatar
Default Re: Need to know if my JDM B18c-R is the real thing!!!! (92TypeR)
i know this is a newbie question. but does all the jdm b18c-r motors have the chrome oilcap?
Old May 19, 2003 | 09:49 PM
fowler!'s Avatar
Default Re: Need to know if my JDM B18c-R is the real thing!!!! (Natural Aspirated)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirated &raquo;</TD></TR><TR><TD CLASS="quote">i know this is a newbie question. but does all the jdm b18c-r motors have the chrome oilcap?</TD></TR></TABLE>
Yeah, they do.
Old May 19, 2003 | 10:10 PM
TypeR 599's Avatar
that valve cover is usdm if that wasn't already stated
btw craig, your fuggin avatar is scaring this **** out of me!
Old May 19, 2003 | 10:12 PM
fowler!'s Avatar
Default Re: Need to know if my JDM B18c-R is the real thing!!!! (TypeR 599)
ha ha
Old May 19, 2003 | 10:14 PM
B2FiNiTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fowler &raquo;</TD></TR><TR><TD CLASS="quote">ha ha </TD></TR></TABLE>
Ypu freak...
01CWITR's Avatar
drive it and test it, maybe u will find out if it's real thing!!
Old May 19, 2003 | 10:30 PM
VTHokie's Avatar
Default Re: Need to know if my JDM B18c-R is the real thing!!!! (01SpecR)
Do b18CR's have green paint on the left side of the head too? I can't tell from your pic.
Old May 20, 2003 | 01:40 AM
GZR4DR's Avatar
Default Re: Need to know if my JDM B18c-R is the real thing!!!! (VTHokie)
Type R motors also have the chrome gromets for the valve cover which this motor does. Hard to tell from the pics. Check for the green paint on the back side of the head near the distributor. There is a good chance it is an ITR motor. There is a slight chance it is not.
